NHRA Rules
Old Mar 3, 2006 | 01:50 AM
F00Mustang's Avatar
F00Mustang
Default NHRA Rules
I'm eager to run in the Fun Ford Weekend comming up in may in Louisiana in the new Ultra Stang class, but I have a convertible. By the time this comes, this car will be well into the 12's. No Problem Raceway follows the same rules as the NHRA rulebook regarding safety and inspections. Does anyone have an NHRA rule book who could tell me if I will run into any problems with tech. I want to know soon so that if any modifications need to be made, I can make them.
Old Mar 3, 2006 | 03:37 AM
carcrazy's Avatar
carcrazy
Default RE: NHRA Rules
track here in vegas you need a roll cage for 12's in a covt. and a heltmet for any 12 sec car
Old Mar 3, 2006 | 04:03 AM
2k1gt's Avatar
2k1gt
I got this off a website. Hopefully it is all correct. You can see it all here also. http://www.importdrag.com/2006%20NHR...20Overview.pdf
NHRA / SFI
SPECIFICATIONS
Mandatory at ET (or quicker) Item All Vehicles
Radiator overflow container
13.99
Drive shaft loop with drag slicks
13.99
Approved rollbar (convertible)
13.99
Approved driver restraint system (convertible)
13.99
Approved helmet
13.49 (IHRA)
Approved flywheel shield (manual trans/solid lifters)
13.00
Drive shaft loop with street tires
11.99
Approved roll bar for all vehicles
11.99
11.99
Approved flywheel shield (manual transmission)
11.99
Approved protective jacket
11.49 (IHRA)
11.49 (IHRA)
11.49 (IHRA)
Approved mounted fire extinguisher
11.49 (IHRA)
Approved flywheel shield (automatic transmission)
10.99
Approved roll cage (convertible)
10.99
Approved harmonic balancer
10.99
Approved after market axles
10.99
Approved transmission shield (automatic transmission)
9.99
Approved flexplate & shield (automatic transmission)
9.99
Approved roll cage & window net*
9.99
Master cutoff switch (also for battery relocation)*
9.99
Competition License*
9.99
Chassis Certification
9.99
Approved jacket/pants/neck collar/gloves*
8.49
Permanently mounted fire system w/ 2 nozzles
7.49
Advanced chassis certification**
7.49
Advanced competition license
150mph +
Parachute required
Old Mar 3, 2006 | 08:12 AM
Crystal's Avatar
Crystal
Either call the track or e-mail them so there is no confusion.
Old Mar 3, 2006 | 08:16 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: F00Mustang
You will need a roll bar, not a cage, there is a differance. You will also need a helmet that meets current specs, along with the basics like overflow can etc. You can buy an NHRA rule book for $10 they are well worth it.
Old Mar 3, 2006 | 08:26 PM
nitrous_bob's Avatar
nitrous_bob
ORIGINAL: 2k1gt
13.99
it's 13.49 and quicker, bur yeah you need a cage.
6 point
Old Mar 4, 2006 | 12:11 AM
JD1969's Avatar
JD1969
Actually I think he can get away with a 5 point bar (no door bar on the passenger side). Also note that a 6 point is not a "cage" unless it has a halo loop.
Old Mar 4, 2006 | 01:46 AM
tinman's Avatar
tinman
I concur with JD on this one......
djbigskrilla
Sep 20, 2022 01:04 AM
Granatelli Sales
Jan 20, 2020 12:34 AM
Sep 16, 2015 03:07 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
adamfrosceno
Aug 27, 2015 07:40 AM
