87 3rd brake light question
Old Feb 16, 2004 | 07:34 PM
lhoard's Avatar
lhoard
Default 87 3rd brake light question
The 3rd brake light on my 1987 GT convertible appears to be very dim. It's possibly a grounding problem. Has anyone got any suggestions on how to trouble shoot this. Thanks in advance.
Lee
Old Feb 16, 2004 | 07:47 PM
90stang's Avatar
90stang
Default RE: 87 3rd brake light question
The 3rd brake light on my 90 GT has two small bulbs, maybe you just have one out. Other than that you can check the voltage going to the bulb and start from there.
Good Luck, Don
Old Feb 16, 2004 | 10:32 PM
lhoard's Avatar
lhoard
Don:
Thanks. I've taken it apart, and one bulb is brighter than the other. I've replaced and changed the bulbs around but that doesn't seem to fix it.
Old Feb 16, 2004 | 10:49 PM
90stang's Avatar
90stang
Lee,
Ok, it is most likely the socket or the wiring splice where the not so bright bulb taps into the wiring of the bright bulb or the wire in between them. The two bulbs are wired in parallel so they should get the same voltage.
Good Luck, Don
Old Feb 17, 2004 | 12:17 AM
hotrodman's Avatar
hotrodman
I ♥ Acer
do the bulbs have the same wattage??
Old Feb 23, 2004 | 09:01 PM
lhoard's Avatar
lhoard
Hotrod man:
How do I check the wattage?
JonnyBlazeGT
Nov 3, 2015 01:10 AM
motown girl
Aug 28, 2015 08:21 AM
bond007
Aug 26, 2015 11:36 PM
cody.hoeppner
Aug 12, 2015 06:39 AM
cody.hoeppner
Aug 11, 2015 08:08 PM
