94 gt suspension??
Old Mar 9, 2006 | 03:10 PM
Deannostang's Avatar
Deannostang
Default RE: 94 gt suspension??
I installed new KYB quads in my '98 GT vert. I also put in Ford Racing rear upper control arms which helped my readend stability. The KYB quads are just $89.99 a pair from Brothers Performance: www.brothersperformance.com I put in Tokico front struts and rear shocks at the same time along with Steeda sport springs. BIG difference in handling. Good luck!
Old Mar 9, 2006 | 04:32 PM
w8less's Avatar
w8less
i agree with whoever said the lakewood traction bars i have them on my 95gt its a pretty easy swap and once u put them in u no longer need the quad shocks. i am surprised ur rims fit with them in general hmmm...........neways just get some good control arms
Old Mar 9, 2006 | 10:42 PM
1BIGMOFO's Avatar
1BIGMOFO
yea i havent tried my rims on the car yet. its on stands in my garage right now. I was loking at them and I dont think they will fit eighter.. Will the traction bars go in the place of the quads? will I have a problem fitting them in? I would like to eliminate them all together. But I am unsure of where exactly the traction bars go and if they will work with the stuff I have.. In the rear, kyb, agx 8 position adjustible gas shocks, upper and lower control arms, ford racing lowering springs, and all urithanne, energy suspension bushings.... where will the traction bars go?
Old Mar 9, 2006 | 11:07 PM
1BIGMOFO's Avatar
1BIGMOFO
there is 2 different sets on sumitracing.com one has a spot for the coil springs one does not. I dont know what ones to get.. i am returning the quad shocks... I know the traction bars are going to be more but hey if its well worth it..... LAK-21900 is the part number of the ones with the coil spring spot. LAK-20161 is the ones with out the coil spring spots..
Old Mar 10, 2006 | 02:55 PM
w8less's Avatar
w8less
they go in place of ur lower control arms. and the part number is LAK-21900
Old Mar 11, 2006 | 12:27 AM
1BIGMOFO's Avatar
1BIGMOFO
so if i have an upper and lower control arm set, and a set of traction bars, I will not be able to use both of them? I got my slp cat back today.. how should she sound??????
Old Mar 11, 2006 | 04:23 AM
ikeybmg's Avatar
ikeybmg
quad shocks are useless when you have lowers because they hold the frame to the axle which was the job of the quads. with quads gone you can fit bigger wheels
Old Mar 11, 2006 | 09:27 AM
1BIGMOFO's Avatar
1BIGMOFO
Will I be able to use a set of upper and lower control arms, plus the traction bars? I was put unser the impression that lower control arms and traction bars go in the same spot... thanks alot
Old Mar 11, 2006 | 06:50 PM
w8less's Avatar
w8less
they do u can only use one or the other if u already have aftermarket lower control arms then there is no need to buy traction bars cause they do the same thing
Old Mar 12, 2006 | 09:57 AM
dsum14's Avatar
dsum14
That is true. Good luck with your swap.
D
baddog671
Jul 26, 2016 01:20 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
