removing 98 front panels
Old Mar 4, 2006 | 06:31 PM
beltrefan's Avatar
beltrefan
Default removing 98 front panels
I need help in removing the front panels on my 98. I know that there are clips, but I don't know where they are or how to pop the panel off.
Thanks!!!
Old Mar 4, 2006 | 07:01 PM
ben5.0's Avatar
ben5.0
Default RE: removing 98 front panels
which panels exactly? the front quarters? bumper ect?
Old Mar 13, 2006 | 12:11 PM
beltrefan's Avatar
beltrefan
the panels on the inside of the front door.
Old Mar 13, 2006 | 04:58 PM
amrcnidyot's Avatar
amrcnidyot
i have a 2000 and its real easy. there is one pin on the front side of the door near the bottom. just pull it out. then take the plastic cover with the electrical switches off by just pulling it off from the top...there is a little notch in the top to pry it off. then unscrew the window switches. you will now be able to see 2 screws in the door. simply unscrew them and ur practially done. now just pull up and a little bit out on the door pannel and it will pop right off. dont know how to post pics but if you want them pm me and ill email them to you.
Old Mar 14, 2006 | 10:23 PM
beltrefan's Avatar
beltrefan
i'll give it a try. thanks!!!!
Old Mar 25, 2006 | 07:50 PM
wild fire's Avatar
wild fire
hello i just joined today .. iam having the same trouble with my 2000 i have speakers in the window (max five) i think that is the name of them . any way i was reading the post for the 2000 just not sure if i have to do something with the speaker when i take the panels off will ihave to remove the speaker .. sorry if this sounds odd .. just not sure what to do and my boyfreind is not to mustang frindly frowning he know trans am anyway if you could help that would be so nice .. if you have pics that would even be better ..
thank you
Sep 16, 2015 07:53 PM
wawagner82
Sep 13, 2015 09:02 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
Sparks_88
Sep 8, 2015 01:06 PM
