Replacing rear brakes
Old Mar 7, 2006 | 08:50 PM
jyarosz's Avatar
jyarosz
Default Replacing rear brakes
I have a 2001 GT and want to replace the rear brakes.I can't seem to get the pistons to go back into the callipers.I heard you have to screw them back in.Is this true and if so how?Is a special tool required? Thank's
Old Mar 7, 2006 | 09:16 PM
ikeybmg's Avatar
ikeybmg
Default RE: Replacing rear brakes
yea you have to have a tool to do it. there may be another way though. they used a thing on mine that forced the piston back in like a vise kinda. so a C clamp might work....just an idea.
Old Mar 7, 2006 | 09:17 PM
razarr69's Avatar
razarr69
i'd think they'd be the same style as a caliper on the front of a fox and i just used a C clamp on it, don't tighten the **** out of it though, just enough to get the caliper back on.
Old Mar 7, 2006 | 09:39 PM
dsum14's Avatar
dsum14
You have to remove the caliper from the bracket and buy the $12 tool to turn the piston back into the caliper. I just found this out doing my rear brakes on my 95. They are differnt than the front, you cannot compress them with a C-clamp.
D
Old Mar 7, 2006 | 09:42 PM
jyarosz's Avatar
jyarosz
I used a C clamp on the front's and they went back in .Doesn't seem to work on the back's.The back's have the emergency brake cable hooked to them and I heard they "ratchet" out. I don't know if I have to unhook the cable or what?
Old Mar 7, 2006 | 11:09 PM
dsum14's Avatar
dsum14
Yes, you have to unhook the cable to pull the caliper off the mounting bracket. Use a big pair of pliers to compress the spring and another pair of pliers to pull the cable off the caliper.
D
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Urambo Tauro
Sep 7, 2015 12:47 PM
bond007
Aug 26, 2015 11:36 PM
Tyoung68
Aug 25, 2015 04:31 AM
Fast-Hands
Aug 19, 2015 06:54 AM
