how much torque to use on struts?
Old Mar 8, 2006 | 11:50 AM
Vash the Stampede's Avatar
Vash the Stampede
Default how much torque to use on struts?
iam going to be installing my camber kit in a day or so. just woundering how much iam supposed to torque down the strut nut and the bolts to the camber plates.. and whatever else nuts iam going to be unbolting and rebolting
or is it even important? am i good just german torqueing it with my arm strength?
Old Mar 8, 2006 | 01:37 PM
dsum14's Avatar
dsum14
Default RE: how much torque to use on struts?
It is a wide range, but I believe it is somewhere around 150 lbs. for the strut nut.
D
Old Mar 10, 2006 | 05:31 AM
jacobs454's Avatar
jacobs454
Sorry, this isn't related to answering your question, but I do have a question for you since you're working with your struts: Are the tops of your struts slotted? If so, what kind of tool did you use to hold the shaft still while tightening/loosening your struts?
Old Mar 10, 2006 | 01:48 PM
dsum14's Avatar
dsum14
They are called binders. They have what look like two washers and a rubber gromet in between. You use a pry bar to bind the two washers and remove the nut.
D
baddog671
Jul 26, 2016 01:20 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
67STANGX2
Sep 24, 2015 12:29 PM
