Sponsored by:
Sponsored by: DashLynx
can stock k-members handle this?
Old 02-21-2004, 04:02 AM
GT99GT
GT99GT's Avatar
Default can stock k-members handle this?
i heard somewhere that stock k members can't handle new offset steering rack bushings but i was planning on changing them to polyurethane.... what do you guys think.... i need to buy them asap because im going to install a bunch of stuff soon... get back to me
thanks
GT99GT is offline
Old 02-23-2004, 05:04 PM
GT99GT
GT99GT's Avatar
Default RE: can stock k-members handle this?
does anyone know????
GT99GT is offline
Old 02-23-2004, 10:45 PM
callmecobra
callmecobra's Avatar
ide just get a tubular man...you will drop some weight, and handle a little better!
callmecobra is offline
Old 02-24-2004, 05:42 PM
Mustang88LXKid
Mustang88LXKid's Avatar
well depends how much he wants to spend cause they can be very pricey. But the best kit I know of that can handle driving the streets is the Maximum Motorsports K-Member kit, it comes with everything you need for your front supsension. You can also buy it alone too, for like 600.
Mustang88LXKid is offline
Old 02-24-2004, 07:51 PM
GT99GT
GT99GT's Avatar
im only gonna change the offset steering rack bushing to polyurethane... can i do that with the stock set up... thats the question
GT99GT is offline
Old 02-24-2004, 09:25 PM
Stratus183
Stratus183's Avatar
You shouldnt have any problams if you use poly-urethane rack bushings.
Stratus183 is offline
Old 02-24-2004, 10:34 PM
vfast
I ♥ Acer
vfast's Avatar
you'll be ok with the bushings
vfast is offline
Old 02-24-2004, 11:28 PM
GT99GT
GT99GT's Avatar
good deal thanks everyone... one last question...
do you guys think that i SHOULD change them to polyurethane ... or just leave them stock
GT99GT is offline
Old 02-25-2004, 06:52 AM
n2o44
n2o44's Avatar
absolutelly not , when you hit a corner hard, the initial shock will flex the rubber junk and once your car settles into the turn , i will come back you will compensate for it while turning you will feel it, get poly or a solid ones , mm offers them and many others , your toe in turns will change like i said when you initally load it , dont use the stock ones , unless your more into a comfortable ride lol, also mm has a write up on not useing offset rack bushings unless you know you are bump steer is excessive ,
n2o44 is offline
Old 02-25-2004, 01:43 PM
hotrodman
I ♥ Acer
hotrodman's Avatar
ORIGINAL: GT99GT
say dude a got your answer ,,yes they will work ,,i have same set up ,,with off set bushings,, also have bump steer kit,,ft coil overs,,90/10 s in ft,, 50/50 in rear s/s/bars..air bag,,s/s/hd tourqe boxes,,frame connectors,, 8 pt roll bar ,,its the **** man im telling you ,,,oh 200lbs springs in ft,,
hotrodman is offline
Quick Reply: can stock k-members handle this?
