tire size difference
Old Mar 12, 2006 | 09:40 PM
GixxStunna's Avatar
GixxStunna
Default tire size difference
whats the difference between a 205 and a 245? I forgot since it's been awhile.
Old Mar 12, 2006 | 10:22 PM
IWinULose's Avatar
IWinULose
Default RE: tire size difference
First number is the cross section width at its widest point. (Contact width in millimeters). The second number in the size will be your aspect ratio and refers to a percentage of your width, which determines your sidewall height. For instance, a 245/45-r17 is this: Width is 245mm at widest point, 45 means the sidewall height is 45% of 245. Finally, the r means the tire is a radial, and 17 is of course the rim size.
Old Mar 12, 2006 | 11:44 PM
GixxStunna's Avatar
GixxStunna
so a 205 has a smaller sidewall than a 245?
Old Mar 13, 2006 | 12:16 AM
gt96stang's Avatar
gt96stang
ORIGINAL: GixxStunna
the tire is narrower.
Old Mar 13, 2006 | 05:15 AM
Magiarn71's Avatar
Magiarn71
Depends on the aspect ratio. The only thing you can say by just the first number, is that a 205 isn't as wide as a 245.....(8" vs 9.6")
Old Mar 13, 2006 | 06:00 PM
GixxStunna's Avatar
GixxStunna
the tires I have now are 245/50/R16 I was looking at a set of 205/50/R16 which one is better?
Old Mar 13, 2006 | 06:10 PM
Magiarn71's Avatar
Magiarn71
Keep the ones you have. The diameter of that second tire is about 1.5" SMALLER and it will mess up your speedo. It is also alot skinnier than what you have. You would need a 205/60 R16 to keep the same diameter and that means more sidewall. If you want it WIDER, then you would need a tire with a higher first number and a lower aspect ratio, like a 265/45 R16....
Old Mar 13, 2006 | 07:23 PM
Deannostang's Avatar
Deannostang
Difference between a 205 and 245......oh, about 75 bucks! Wider is better, don't forget that.
Old Mar 13, 2006 | 09:23 PM
GixxStunna's Avatar
GixxStunna
sweet thanks guys
NorthAmericanTuning
Nov 9, 2016 11:44 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Gary Ugarek
Sep 16, 2015 08:04 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
