Cant figure out what psi to run in et streets
i got 26x11.50 r17 and i have tried from 16-19 so far at the track with my 05 mustang GT ive got 3.73 gears 4000 - 4500 rpm launches i need some help with psi is there a website with a ratio?? like weight to power and thingS??
RE: Cant figure out what psi to run in et streets
Trial and error man, you might even need to change pressure as the day goes on and the track changes. I start at 20 psi and drop them untill the 60 foot falls off, but every car is different. BTW you don't want to go too low or they will cup.
that and might spin off the bead too.
i was launching from off idle to 4k till i found a sweat spot...that's why they call it test,and tune.
get a buddy to tape you also...it might feel good in the car,but outside it might look like you need to make changes.
I found 12 psi works best for us and most of the guys we run with if your tires are new it will take around 10+ runs for them to start working good anway.
09-08-2015 06:25 PM
09-01-2015 08:16 PM
kawiguy827
09-01-2015 07:09 PM
