Problem with Ford Customer Service
Old Mar 18, 2006 | 01:57 AM
Cobrakev's Avatar
Cobrakev
Default RE: Problem with Ford Customer Service
ORIGINAL: MTShambles
If you are out of your warranty they might not help you at all.
TSB's are only covered when you are under your cars warranty.
Sorry this is wrong. TSB are covered anytime. I had the salt and pepper shakers changed on my 89 stang after the warranty ran out.
Kev
Old Mar 18, 2006 | 01:58 AM
XxXRacingUnleashed's Avatar
XxXRacingUnleashed
i would just go to ford
Old Mar 18, 2006 | 03:24 AM
03YellowPony's Avatar
03YellowPony
ORIGINAL: XxXRacingUnleashed
He's already gone over the heads of the dealership. Going to any dealer now is redundant
Old Mar 18, 2006 | 02:00 PM
ShadowDrake's Avatar
ShadowDrake
ORIGINAL: Cobrakev
Kev
TSBs are warranty only. I was told this at my dealership too because my transmission is displaying symptoms from pretty much every single transmission related TSB for 04 GTs. Guy at the dealership told me he would give me a call when they had an opening to schedule me a time and never called, essentially blowing me off. RECALLS are done regardless of the status of your warranty.
If you got TSB work done after your warranty is out, you must have asked them on a good day, or they just didn't know.
Old Mar 18, 2006 | 09:00 PM
2005MustangGtGuy's Avatar
2005MustangGtGuy
Unless your car is under warranty, they will not work on it for free. A TSB does not = free work. Here is the definition of a TSB
Technical Service Bulletins (TSBs) are issued by vehicle manufacturers to help automotive technicians diagnose and repair problems reported by consumers and repair shops. It's amazing how many fixes are found in these bulletins that can't be found anywhere else. Thousands of bulletins are issued by car manufacturers every year.
TSBs contain up-to-date factory fixes for difficult to diagnose problems such as rough idles, intermittent stalls, hard starts, and all kinds of "shakes", "rattles" and "clunks" that can sometimes drive you nuts. TSBs describe service procedures that may improve performance, reduce future breakdowns, or show a factory authorized modification for your vehicle.
^^^^ is from http://www.alldata.com. $2800 to rebuild a transmission is rediculous..Id call a few transmission shops and see what they would charge for a rebuild. My guess is its under $1000. Since you have fairly low mileage, see if ford will help cover the cost of the rebuild..good luck
Old Mar 19, 2006 | 12:45 AM
stang01's Avatar
stang01
I stated that the estimate was for $2,800 plus tax. That was wrong. It included tax.
I also gave the impression that third gear was my only problem. In fact 3rd gear is my biggest problem. I also have a notchy feel in all gears. And trouble shifting into lst and 2nd when the wheather is cold.
The rebuild kit for this transmission is 3R3Z-7124-AC. It includes revised components. Including a Synchro kit, main shaft gears, shift forks and rail assemblies, and block rings.
The kit costs around $1,326. I am unable to find this kit and price now but I took notes when I found it. Just not where I found it. I will find it again.
Old Mar 19, 2006 | 12:56 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: 2005MustangGtGuy
I was just gonna say the same thing. WE deal w/ this quite often at our shop. Good find on the info!!
Old Mar 19, 2006 | 01:05 AM
Tac2cul's Avatar
Tac2cul
if u go to Genuine Ford Parts
they have the kit for 940 bucks and change
Old Mar 19, 2006 | 01:07 AM
2005MustangGtGuy
Search around on http://www.parts.com for your part#..This place http://www.trademotion.com/partlocat...&siteid=214290 lists the rebuild kit at $860..
Old Mar 19, 2006 | 01:09 AM
Tac2cul's Avatar
Tac2cul
even better
