Sound @ 3K+
Old Mar 21, 2006 | 04:27 PM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
Default Sound @ 3K+
Got the GT out yesterday, noticed a sound today [8D].. figures.lol
its noticeable whether im in gear under light acceleration, or in nuetal revving a bit up to 3K where it starts.
With the doors closed, it sounds like its coming from up front in the engine or somewhere, but with the door opened, it sounded more from underneath.
It isnt really a plastic ping,, almost like a plastic whirring sound (not throwout bearing, that hasnt started back up this spring yet)
does anyone think they can make a prediction with such a crappy description.?
thanks
Old Mar 22, 2006 | 01:31 PM
72MachOne99GT
Default RE: Sound @ 3K+
well, nobody has any suggestions?
its a squeak like sound that gets loud the higher i go in the rpm range
it is noticeable in all gears too, not just in 5th
no suggestions? maybe a pulley'd loose? i dont konw...
Old Mar 22, 2006 | 04:47 PM
FastLane034's Avatar
FastLane034
Well, I dont know too much about fixing noises, but my car did something almost just like it, and the alternator was the cause. Check your alternator, it might need work or replacing.
Old Mar 22, 2006 | 04:57 PM
ShadowDrake's Avatar
ShadowDrake
ORIGINAL: 72MachOne99GT
It's possible you could have a pulley bearing going out. Probably the idler pulley. Your description of being in gear and out makes it tough to say though. Just try bringing your RPM up while sitting still in neutral (clutch in, too) and report the sound. That may help us out.
Old Mar 22, 2006 | 05:41 PM
bdwjdw's Avatar
bdwjdw
I know you said it wasn't the throwout bearing but that is what it sounds like to me. Does it do it when you are pushing in on the clutch?
Old Mar 22, 2006 | 05:44 PM
Derf00's Avatar
Derf00
Gentleman's Relish
thanks
Easy way to check the bearing on the Alt/WP/PS/and Idler, Take the belt off with the car cold. Start it up. If it goes away, shut the car off and hand spin all the accessories, see which accessory has the bad bearing. If it still exists then it's the throwout bearing. I got the same sound in my car after I had the clutch replaced. The throwout bearing they put in crapped out after about two weeks. The replaced and no problems since (3 months now)
Old Mar 22, 2006 | 08:40 PM
72MachOne99GT
its not the throwout, but i udnerstand why you might think iti s
last year the throw out bearing was making noise, and it was OBVIOUSLY the throwout bearng
it just hasnt started back up this year,
i'll try to thingy with the belts, so start it cold w/o the belt
then if it isnt present, hand spin the pulleys??
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
