just installed A/C clutch
Old Mar 22, 2006 | 09:39 PM
93stallion302's Avatar
93stallion302
Default just installed A/C clutch
ok i just installed the A/C clutch on my 93 5.0 and it cools fine and all, but the clutch stops and starts turnin randomly while the A/C is on. It also screeches wen it starts to spin then stops. Any ideas if that normal, or the clutch needs a break in time, or did I royally screw up on the install?
Old Mar 22, 2006 | 09:54 PM
Chopper's Avatar
Chopper
Default RE: just installed A/C clutch
Starting and stopping is normal but the noise when the clutch is engaged is not.If the system was discharged you might have to replace the compressor and have the system cleaned and recharged.The noise could be coming from the lack of lube in the system or the compressor could be corroded to the point of not wanting to turn.This would cause the belt to squeal,there should be no slipping of the A/C clutch.
Old Mar 22, 2006 | 10:18 PM
93stallion302
thx for the reply hopefully it isnt the compressor, could the wrong air gap cause the screeching? Wasnt real meticulous about that
mtgldr
Feb 3, 2024 09:00 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Emblazoned
Sep 3, 2015 10:45 PM
