PVC Valve
Old Mar 23, 2006 | 11:51 PM
moparmatt89's Avatar
moparmatt89
Default PVC Valve
Hey,
I was getting a greyish white smoke out of my tailpipes for the first time yesterday. I dont think its a bad head gasket cause i just bought and installed new ones. I also drained the oil today and there was no traces of coolant. The engine was just rebuilt and has had no problems with smoking. This is why i dont think its a bad ring. It was coming out of the pasenger side more than the driver side. I was wondering if a bad PVC valve could cause this. I looked at the rubber vacum hose to the carb form the PVC and i found some traces of oil. The vacum line enters on the passenger side of the carb. Is a bad PVC whats causing this?
Thanks
Matt
Old Mar 24, 2006 | 04:33 PM
turbostang21's Avatar
turbostang21
Default RE: PVC Valve
it certainly could be a pcv...change that first and the screen and check the hose for leaks. could also be a lower intake gasket. if that doesn't cure the problem do a compression test. did you properly break in the motor?
Old Mar 24, 2006 | 04:48 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
ORIGINAL: turbostang21
LOL. I wondered who would correct that. Very subtle turbostang. nice [sm=smiley20.gif]
Old Mar 24, 2006 | 05:54 PM
alexr's Avatar
alexr
maybe his is made out of PVC[&:][8D]
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
69Volunteer
Sep 30, 2015 10:39 AM
lmurf60
Sep 24, 2015 10:07 PM
