Fix "curbed" rims
Old Mar 26, 2006 | 01:52 AM
Smooth_J's Avatar
Smooth_J
Default Fix "curbed" rims
Is there anyway to fix those "curbed rims" - rims that have hit the curb one too many times? :P
Thanks!
Old Mar 26, 2006 | 02:10 AM
kartracer55's Avatar
kartracer55
Default RE: Fix "curbed" rims
What are you looking to fix? What is wrong with them? What sort of finish is on them?
Jim
Old Mar 26, 2006 | 02:18 AM
Smooth_J's Avatar
Smooth_J
ORIGINAL: kartracer55
Jim
I am looking to fix the molding around the outside of the rim (where it hit the curb). Its a straight aluminum finish.
Old Mar 26, 2006 | 02:20 AM
ShadowDrake's Avatar
ShadowDrake
He's looking to fix up curb rash... I've heard a story of welding a piece of metal over the rash spots and with lots of careful grinding they were able to make it look like new but that's a step above most people's at-home abilities, and patience... There's a couple clever fixes for curb rash around, someone probably knows, I don't remember though.
Old Mar 26, 2006 | 03:29 AM
tictac's Avatar
tictac
get new rim(s) ?
Old Mar 26, 2006 | 04:23 AM
alexr's Avatar
alexr
bondo and spray em chrome[8D]
Old Mar 26, 2006 | 01:07 PM
antiv6's Avatar
antiv6
i have some curb rash but you only notice it when your washing the rims, dam previous owner.
Old Mar 26, 2006 | 01:28 PM
kartracer55
Are they just plain aluminum? I mean is there any coating on them?
I have done a few fixes on aluminum before, and I am going to warn you now... it will never look like It did when they were new, BUT you can minimize thier appearance.
First, you are going to need either a dremel or an air die grinder.
The attatchment you want to use is called an abrasive "buff" its a sort of rough nylon? wheel that will gently smooth out the metal... You know how metal seems to get chewed up? Well these will sort of smooth that out... if you look closely they will still be there of course.
These are the attatchments for the dremel...
http://www.dremel.com/en-us/attachme...188569&G=66429
You will need the arbor for to use these too, the wheels are a couple $ and the arbor is a couple $. Id say a course/medium wheel, the fine and the arbor should be about 10$.
OR if you have an air grinder, you can get larger 1/4 shanks from MSC.
Go to MSCdirect.com and search the following part numbers (cant link directly to an item)
Course 00066324
Med. 00066316
Fine 00066308
Extra fine 00066290
They are 2.63 a piece, you pick what you want. Id say go for a med and a fine, and when you start with the medium, if its taking too long, order a course. They ship pretty fast, I have gotten stuff next day when they ship it "ups ground"
Jim
Old Mar 26, 2006 | 04:47 PM
Smooth_J's Avatar
Smooth_J
Course 00066324
Med. 00066316
Fine 00066308
Extra fine 00066290
Jim
Nice, thank you!
One question though, once I grind the rash down, is there anything I can use to polish it back up?
This is the kind of wheel I have now:
[IMG]local://upfiles/14091/3BF31EE8FB4C414C876739B1631C774F.jpg[/IMG]
Old Mar 26, 2006 | 05:01 PM
kartracer55
Arnt those wheels gun metal? I dont Think you are going to be able to polish those back up because there is a finish on them, you are going to need some sort of touch up paint for them
Jim
