Help need on heater
Old Mar 27, 2006 | 11:21 AM
Thrill Racer's Avatar
Thrill Racer
Default Help need on heater
My car al most over heated, and now my its not blowing any air out of any of the vents, so i have idea what is wrong with it and i dearly need some help, its still cold in Idaho in the mornings.
and i also just found out that I'm leaking coolent, couls this be part of the problem.
Old Mar 27, 2006 | 11:33 AM
BraMas's Avatar
BraMas
Default RE: Help need on heater
Your probably are to low on coolant. The heater core uses the coolent that flows thru it to heat your car. If there is no coolant you have no heat. Or worse yet your gonna blow your engine.
Old Mar 27, 2006 | 02:46 PM
mustang_montana's Avatar
mustang_montana
when my heater core went out i didnt realize it until my car died from overheating. the coolant drained all under my carpet. check around for coolant leaking inside of your car, if its your heater core you should bypass it untill you get it fixed, so you wont be pissing out more coolant. id also check the thermostat just for the hell of it, that messed up my heater too, but that wouldnt be why you are leaking coolant.
Old Mar 27, 2006 | 03:09 PM
ByPopularDemand's Avatar
ByPopularDemand
Add coolant then let it run if the resevoir empties add more, then check for warm air out of the heater
Old Mar 27, 2006 | 04:11 PM
Thrill Racer
thanks u guys
it is greatly apreaciated
djbigskrilla
Sep 20, 2022 01:04 AM
mrtrodonet
Sep 19, 2020 03:12 PM
Seanam
Oct 4, 2015 10:15 AM
Wesley1995
Aug 30, 2015 02:01 PM
Calizic
Aug 28, 2015 01:46 PM
