347 STROKER PROBLEMS
Old Mar 27, 2006 | 02:26 PM
88stanggtconv's Avatar
88stanggtconv
Default 347 STROKER PROBLEMS
I JUST GOT MY 347 BACK IN MY CAR AND IT WON'T IDLE AND I NEED SOME HELP. I TOOK THE ROLLER CAMSHAFT OUT AND DUE TO MONEY RESTRAINTS COULDN'T GET THE NEW ROLLER CAM I WANTED. SO I WENT WITH A HYD FLAT TAPPET CAM. NOW MY PROBLEM IS THAT THE CAR WON'T IDLE AND SEEMS LIKE IT IS RUNNING ON LESS THAN 8 CYLINDERS. I'VE CHECKED ALL VACUUMS AND THEY SEEM CORRECT. SINCE I CHANGED THE CAM TO A NON ROLLER DO I NEED TO CHANGE THE COMPUTER TO A NON HO COMPUTER?
[IMG]local://upfiles/32494/CB703F07FD7248789C1A3D2076793853.jpg[/IMG]
Old Mar 28, 2006 | 06:33 AM
Magiarn71's Avatar
Magiarn71
Default RE: 347 STROKER PROBLEMS
Check firing order/timing.
Old Mar 28, 2006 | 11:57 AM
alexr's Avatar
alexr
try taking off the caps lock
Old Mar 28, 2006 | 12:22 PM
angcobra's Avatar
angcobra
ORIGINAL: Magiarn71
+1
Old Mar 28, 2006 | 04:32 PM
Cobrakev's Avatar
Cobrakev
H.O. cams and stock 302 cams have a different firing order as said above. I would try that first.
Kev
Old Mar 30, 2006 | 10:44 PM
88stanggtconv
Thanks for all the help guys i did have to change the firing order and also the TPS needed adjusted. Now I am replacing the flywheel and balancer due to misinformation, thank god I didn't drive it for to long with the engine unbalanced
Old Apr 2, 2006 | 01:25 PM
angcobra's Avatar
angcobra
Did you 50oz on 28oz motor or visa versa?
Brett Ludlow
Sep 23, 2015 06:59 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
