How to do a 5.0 oil pan gasket replacement?
Not much.What you need to do is unbolt the motor mounts and any LIFE LINE or wires that will be in the way and then jack the motor up far enough to clear the cross member.Other than that its easy a little time consuming but not hard.
Do not let the fact that you need to jack up the motor scare you its nothing major.
make sure to use a one piece oil pan gasket, fel-pro makes it, its a lot easier and worth the extra money. clean all of the oil around the pan and just look to see if your rear main is leaking, if its leaking you will be able to tell
soulcaliber39
Dec 28, 2016 04:57 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
