Slicks
Old Mar 3, 2004 | 03:55 PM
Fast92's Avatar
Fast92
Default Slicks
I'm going racing this year, and would like to know what slick's you drag racers are running. I am running a 92 LX with a 347 stroker with a 150 shot NOS.I don't care about the cost ,I just want to hook up.
Old Mar 3, 2004 | 04:22 PM
callmecobra's Avatar
callmecobra
Default RE: Slicks
ide recomend bfgoodrich dr. they are the best dr you can get, but you will be lucky to get 10,000 miles out of them....
Old Mar 3, 2004 | 05:04 PM
red347's Avatar
red347
Default RE: Slicks
Since you are asking about "slicks", I run a Mickey Thompson 10.5 x 28 x 15 slick, with inner tube. No slick seems to hold air for very long, so I went with tubes. Racing every weekend, they will last about 1 full season. If you run tubes however, I would suggest you use rim screws.
On an earlier car I run a MT 9 x 26 x 15. Had a couple of spare steel wheels I mounted them on, drove to the track, mounted the wheels w/slicks, raced, and at the end of the day put the street tires back on. I ran about 10 pounds of pressure.
I should warn you, that with a good burn out, they will hook. They will also find every weak spot in your drivetrain (if there is one).
Lastly, the car will feel real soft when you lift at the top end of the track. Takes a while to get used to.
Ron
Old Mar 3, 2004 | 06:23 PM
WNDSOR's Avatar
WNDSOR
Default RE: Slicks
yeah i agree with red, use a true "slick" like the M/T's or Hoosiers, you'll love them. i run with 26 x 10.5 x 15, they will pin you in your seat!
Old Mar 3, 2004 | 08:56 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: Slicks
get yourself a pair of et's ...you come out 4-5krpm on these you'll be pick'in up a ring -pinion set
Old Mar 4, 2004 | 01:59 PM
Fast92's Avatar
Fast92
Default RE: Slicks
Thanks for all of your help. I will try looking at all the tires you guy's,and pic from there.
Old Mar 4, 2004 | 03:39 PM
hotrodman's Avatar
hotrodman
I ♥ Acer
Default RE: Slicks
MAX TRACTION GET HOOSIER 27X11.50 X15 DONT RUB LIKE THE MT 28 12.50X15..MOUNT ON 10X15 IN WHEELS WITH 6.5 BACK SPACE ,,LOOKS GOOD ,,DONT STICK OUT ALL UNDER THE FENDER,,,,
ctgreddy
Oct 14, 2015 09:05 PM
Dragonus18
Sep 9, 2015 01:21 AM
gearhead4ever
May 23, 2004 04:43 AM
3000ways
Apr 27, 2004 04:37 AM
03gtvt
15
Nov 12, 2003 12:13 AM
