Problem starting the car
Old Apr 7, 2006 | 05:12 PM
Sergey's Avatar
Sergey
Default RE: Problem starting the car
ORIGINAL: Chopper
ORIGINAL: Sergey
ORIGINAL: PRO50SC
Try this. Before you start the car, prime the pump a few times. Key on, key off. 2-3 times. Then start it. If it fires right up, it's most likely the pump. Very rare do the injectors leak down. They do, but it's rare.
tried that,it started pretty quick...
If it is the fuel pump,has anyone here replaced a fuel pump? how hard is it to do yourself and can it be done without any special equipment that authorized mechanics have?
thanks for all the help
Run as much fuel out as you can before you start the job,that makes the work a lot easier.Basic tools are all you really need,a floor jack really helps when reinstalling the tank.
FORD,,,,NOW HEAR THIS.Cut a hole in the body above the fuel pump so we don't have to drop the d#*n tank to fix these things!!!![:@]
so,you're saying it's not that hard and is not worth $350 for the labor at my mechanic's?
how long does it take to change the fuel pump,i know dropping the tank will be a pita
Old Apr 7, 2006 | 06:50 PM
dsum14's Avatar
dsum14
I had a problem like this once. You may not have to change the pump if you don't have the money. When you drop the tank, check the sock first. If its dirty, it will cause the same problem. I would replace the pump anyways since I was already in there, but that's just me. To drop the tank, it is two bolts holding the straps. Place a jack under the tank and lower it down slowly. You will need a set of fuel line tools, maybe $5-10 at the autoparts store. Disconnect the lines and electrical connection and it drops right down. Use a screw driver and a hammer to release the retaining nut around the outside of the sending unit. Remove the sending unit. Once you have this out, it is very self explainatory to remove the fuel pump. Only things you need to know from here are to make sure the sock/pump/sending unit are dropped directly in between the two metal half walls located at the bottom of the tank and make sure the lines CLICK when installing them back on the sending unit. This is very simple and should only take about an hour if your bolts aren't too rusted. Have a friend help with the dropping and reinstalling of the tank, it will help being your first time. I do it myself, but I have had an instance when I had 3/4 of a tank and had my wife help me install the tank. Good Luck and don't be afaid to try it yourself.
Old Apr 8, 2006 | 01:36 AM
Sergey's Avatar
Sergey
will do, thanks a lot[sm=smiley20.gif] man
Old Apr 9, 2006 | 12:02 AM
dsum14's Avatar
dsum14
No prob. Good luck.
Old Apr 9, 2006 | 02:34 AM
joepilot's Avatar
joepilot
I just picked up a 1995 coupe v6 for my son... havent thought to much about it yet but the car is also pretty hart to start when cold..... 3 or 4 times to get it going then starts right up. one other thing i smell fuel lightly not much... no visible leaks... guess ill check out the fuel pump.... any ideas on the smell
Old Apr 9, 2006 | 11:07 AM
dsum14's Avatar
dsum14
Rear or front of the car? I'd check the filler tube gasket and sending unit if coming from the back. If from the front, I would check the injectors. Can you be a little more specific?
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
jjwinel78
Aug 17, 2015 03:34 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
