ignition trouble please help
Old Apr 9, 2006 | 06:16 PM
gt86's Avatar
gt86
Default ignition trouble please help
i have an 86 gt all stock. it recently started missing and now wont start . ihave found that there is no spark coming from the coil. i replaced the coil but still no spark. tfi maybe? please help
Old Apr 9, 2006 | 10:14 PM
Chopper's Avatar
Chopper
Default RE: ignition trouble please help
The module inside the distributer could be bad.You could use a voltmeter to check for voltage to the coil to help track down the cause.
Old Apr 10, 2006 | 10:41 PM
gt86's Avatar
gt86
i replaced the tfi and it fired right up. it ran for a minute or two then started missing & died again. thanks 4 the tip i'll give it a shot
Old Apr 11, 2006 | 03:16 AM
P.S.I.cho's Avatar
P.S.I.cho
most likely your stator inside the distributor, usually if u replace the tfi u should replace the stator at the same time
CS2007
Jun 25, 2019 09:45 PM
bradleyb
Nov 27, 2015 07:50 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Wombatnation
Sep 13, 2015 09:16 PM
