i think i may have fixed my mileage problem a little...
Old Mar 13, 2004 | 04:26 PM
bmorrisj's Avatar
bmorrisj
Default i think i may have fixed my mileage problem a little...
i am stoked, i just drove 100 miles on 6 gallons of gas, an there is still a bit to go on the gas guage; i dont know how low it goes before its really empty and i dont want to find out. but there is still a few miles in there.... but its wierd, i put a mallory hyfire VIA in there and set my fuel pressure to 50psi vac off , i put some injector cleaner in there and hoped the extra fuel back pressure could push it through a bit harder to scrub some more ... this is coming from barely 60-70 miles on 6 gallons.....
Old Mar 13, 2004 | 05:15 PM
jeep45238's Avatar
jeep45238
I ♥ Acer
Default RE: i think i may have fixed my mileage problem a little...
Damn.....what the hell man. That's....bad. Hell, stock heads/intake/block.....with exhaust, CAI, and a stroke you shouldn't be that bad.
Old Mar 13, 2004 | 07:41 PM
bmorrisj's Avatar
bmorrisj
its been worse ever since i got the car, still needs a coil and control module along with some new clean injectors, im just glad my problem is a bit smaller now...
Old Mar 13, 2004 | 09:46 PM
vfast's Avatar
vfast
I ♥ Acer
have you cleaned your 02 sensors yet?..this will help if your using the 19's you can find a set with low miles for close to nothing....only REAL way to clean them is to pull them out or send them off the be matched flowed...also changed that pcv valve to a higher number this wil clean up things..
Old Mar 14, 2004 | 08:18 AM
bmorrisj's Avatar
bmorrisj
i already put a new pcv valve in there like 3 weeks ago.... i just got my xpipe today, i have to go put it on, so im gonna put some new o2 sensors on that, should i clean mine or get new ones because i have not gotten any CEL action.....
Old Mar 14, 2004 | 01:11 PM
vfast's Avatar
vfast
I ♥ Acer
I would spend the 90.00 for new ones..did you clean the screen where the pcv valve goes in?
Old Mar 14, 2004 | 04:35 PM
bmorrisj's Avatar
bmorrisj
oh yea, i found a new breather screen at the local speed shop at the same time, kragen and autozone didnt even have it in their computers...
Old Mar 14, 2004 | 08:04 PM
vfast's Avatar
vfast
I ♥ Acer
cool..most just throw them away
Old Mar 15, 2004 | 02:35 AM
bmorrisj's Avatar
bmorrisj
i just noticed that the current piping on the car doesnt have an equalizer tube, just the small egr tube....
zanemoseley
Sep 6, 2015 12:58 PM
TimeLord101
Sep 4, 2015 09:27 AM
5.0 kevo
Sep 3, 2015 06:24 PM
