header wrap?
Old Apr 15, 2006 | 12:14 AM
Valcore's Avatar
Valcore
Default header wrap?
Im watching that ricer show called tricked out on diy and the guy is putting wrap on the new header to reduce heat...
it looks like a good idea if it works, so does anyone know if it works?
Old Apr 15, 2006 | 12:19 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: header wrap?
It really does not give you any hp, plus the wrap voids most companies warrenties, due to the wrap causing the header to rust.
Old Apr 15, 2006 | 02:30 AM
beheivjer's Avatar
beheivjer
i use it on my turbo setup helps keeping the heat out it acts like an insulated chimney flows out better
Old Apr 15, 2006 | 03:12 PM
anthonydalrymple's Avatar
anthonydalrymple
Header wrap does indeed void any warranty. The company I work for voids it because keeping all the heat in the header decarbonizes the steel tubing faster than without the wrap. The higher the exhaust temps in the tube; the faster steel tube decarbonizes. I've seen the long tube headers with fractured & blown out sections in the tubes at work & the wrap marks left on the header's people try to get our company to warranty..... It's really up to you. Yes, header wrap insulates extremely well & costs less than ceramic barrier coating or Jet Hot.
Old Apr 15, 2006 | 06:57 PM
JD1969's Avatar
JD1969
But in the long after going threw the hassle and price of an install and then a voided warrenty, ceramic coating is actually a decent deal, besides it looks better and does not fall apart like the wrap.
Old Apr 15, 2006 | 07:03 PM
randy78045's Avatar
randy78045
+1
Old Apr 15, 2006 | 07:32 PM
Valcore's Avatar
Valcore
yeah i just got back from advanced for a battery cable and saw the header wrap, they wanted 45 bucks for one roll and it says it needs a roll for each header, considering the headers I just got are a total of $200, the wrap dosn't seem like that great of a deal anyway
thanks for the help
Old Apr 15, 2006 | 09:30 PM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
Another thing about the header wrap, it is my opinion on a street car that see's rain it will cause the floor boards to rust too.
The prev owner of my car had it on the collectors, I ASSume to reduce the heat on his feet or something, I don't know. Anyway, on the drivers side floor board right above the collector I had a patch of rust. Maybe coincidence but I think the wrap gets wet, then as the engine/exhaust gets hot it turns to steam, the steam hits the floorboard and creates rust. Purely my opinion.....
Old Apr 16, 2006 | 01:24 AM
BraMas's Avatar
BraMas
I wouldn't use header wrap on any car that has the potential of driving through rain. the moister will get trapped against the header and make it rust out faster than they already do. IMO header wrap is for off road vehicles
Old Apr 16, 2006 | 04:12 AM
tinman's Avatar
tinman
Don't use it unless you want to buy a new set of headers every year......
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Roxon68
Mar 17, 2016 08:13 PM
junior04
Sep 28, 2015 10:53 AM
Sep 18, 2015 06:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
