headlights
Old Apr 16, 2006 | 01:28 AM
Guest
Guest
Posts: n/a
Default headlights
my right low beam has gone out, i replaced with new oem bulbs and still nothin.
high beam works great.Where do i begin
Old Apr 16, 2006 | 05:00 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
Default RE: headlights
you begin by spraying some WD40 into the connection between the bulb and the harness. If that doesn't work, then start checking your fuses
Old Apr 16, 2006 | 08:29 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Prolly a short in the low beam circuit. Could be in the plug itself. Check it w/ a test light.
Oh, does the low beam on the other side work?
StalkerGT
Nov 28, 2015 03:09 PM
Seanam
Oct 4, 2015 10:15 AM
Drastang
Sep 29, 2015 03:31 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
