need a wiring expert
Old Apr 18, 2006 | 09:00 PM
ocf's Avatar
ocf
Default need a wiring expert
1994 5.0 stang with a wiring problem, battery goes dead in a week, found tan wire that plugs into headlight switch melted. the wiring diagram in my repair manual showes no such tan wire, can anybody tell me what it goes to, im guessing the fog lights since they havent worked in a while
Old Apr 20, 2006 | 03:22 PM
anthonydalrymple's Avatar
anthonydalrymple
Default RE: need a wiring expert
I'm no wiring expert nor anywhere near being good at it. But since no one else has responded & you needed a TTT.....
I'd check for a draw at the battery, make sure I had a good charge on the battery, clip the tan wire in the middle of the burned section, & then see if the draw dissapeared at the battery or not. A multimeter would work for sure; you might be able to do it with a test light(?) If the tan wire was not the problem; no big deal since you needed to replace that burned section of wire anyways. Then I'd move on to pulling fuses & rechecking for the draw at the battery to narrow down the problem circuit....
Old Apr 20, 2006 | 08:10 PM
Tac2cul's Avatar
Tac2cul
ORIGINAL: ocf
you mean the switch in the dash to the left of the instrument cluster that turns the lights on and off?
is it tan/white?if so it goes into your fuse box and uses a 15a fuse
from there it changes to black/orange and goes to main switch light and also offshoots to a fuse block
Old Apr 20, 2006 | 10:33 PM
ocf's Avatar
ocf
Thanks for the info guys, now I have a plan of attact
Old Apr 20, 2006 | 11:55 PM
sofknez's Avatar
sofknez
I Dont know if you would be interested, but I have a ford cd that has every nut and bolt on a 94 mustang and other 93 and 94 ford cars. I will send you a copy if you would like?
Old Sep 25, 2007 | 11:35 AM
houg09's Avatar
houg09
I would pay for a copy of that. would be a big help
thanks
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Dathan
Oct 5, 2015 05:52 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
