transmission pan seal?
Old Apr 20, 2006 | 03:55 AM
thehourg's Avatar
thehourg
Default transmission pan seal?
i was wandering, i already installed and torqued the bolts to the tranny pan, but i see a few drops of fluid by the trans.. yoke, since the seal has already been made, would it be wise (would this break my seal) to try and tighten the bolts nearest the yoke to see if this would get rid of the minor fluid drops? or do i leave it alone? PS. i have dropped this pan before and had a lot of probs, thats why i am leary about screwing around with it anymore than i have to...
Old Apr 20, 2006 | 03:06 PM
anthonydalrymple's Avatar
anthonydalrymple
Default RE: transmission pan seal?
I'd clean all fluid off, start the car, don't drive it, & see if fluid reappears. It could be the tailshaft seal leaking & making it look like the pan seal is bad. Although less likely; shift selector seal and\or speedo cable o-ring seal is bad & the fluid is blowing back to the pan\tailshaft area(misleading you). If no fluid appears while up to operating temps in the driveway; then drive it slowly around the block once or twice before reinspecting..... Good luck!
Old Apr 20, 2006 | 08:31 PM
thehourg's Avatar
thehourg
thanks man, im kinda thinking the same thing, possibly the seal in the back of the tranny could be letting out a few drops here and there....
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
b8checker
Sep 30, 2015 07:11 AM
