2000 Mustang front end noise
Old Apr 24, 2006 | 09:09 PM
Duponttwa's Avatar
Duponttwa
Default 2000 Mustang front end noise
I have a 2000 Mustang with the 3.8 V-6. When I turn to the left or right with car stopped I hear a squealing when the wheel is straight no noise(same noise while driving). My first thoughts was power steering fluid, but it was full. Then I thought it was the serpentine belt ot the steering pump was bad. The strange thing is I hear the same noise when I am on a bumppy road or going up a gravel driveway with wheel straight. Also I can go out and push up and down on the front hood and hear what sounds like the same noise. I thought maybe it just needed greesed some where but the guy at the garage said there was no fittings on the front? Has anyone else ever had this problem? Could it be the belt or struts.....or something else???"
Old Apr 24, 2006 | 09:14 PM
Tac2cul's Avatar
Tac2cul
Default RE: 2000 Mustang front end noise
read dis
https://mustangforums.com/m_1289682/tm.htm
Old Apr 24, 2006 | 09:17 PM
jlong00's Avatar
jlong00
Could be lower control arms. Unfortunately I had a similar issue with mine. Front end would make a scrunching sound as I firmly applied the brakes at low speeds. (if I 'rocked' the car)
Luckily the car was still BARELY under warranty, so Ford took care of it. I would speak with someone at the dealership about it.
Old Apr 27, 2006 | 04:21 PM
I_AV8_4U's Avatar
I_AV8_4U
Hey Dupon...
May sound odd, but I ran into this with my '98 Taurus. Funny squeaking noise when I turned, and occasionally with bumps. Turned out to be outer tie rod ends. Before I found this, I replaced the PS pump, belt, dlr inspected rack, and removed the rubber/plastic through the firewall! I luckily found this by accident and it worked great!
Good luck,
Troy
Old Apr 27, 2006 | 05:28 PM
SXGT's Avatar
SXGT
i had that problem and i took it to an under care place and he just greased up some stuff and ive never had the problem since.
Old Apr 30, 2006 | 01:56 AM
Duponttwa's Avatar
Duponttwa
Troy you are the man, it was the outer Tie Rod Ends. The garege had me thinking it was the Ball Joints as I was inspecting them I popped off the Tie Rod and noticed the squeak noise was comming fron there. What a difference a quite Mustang sounds, Thanks everyone for all of your suggestions but Troy is the winner!!!
Old Apr 30, 2006 | 01:20 PM
I_AV8_4U's Avatar
I_AV8_4U
<<<Blush
Glad to help. Like I said, this drove me crazy for a long time until I stumbled upon that cure. I wouldn't have thought in a million years it was the tie rod ends!
Troy
svastano
25
Jul 16, 2016 01:20 PM
01blackgtconv
Aug 14, 2015 04:50 PM
daytooday
Aug 11, 2015 09:22 AM
01blackgtconv
Aug 10, 2015 01:25 PM
tmdm
Aug 7, 2015 10:24 PM
