gear swap in progress
Old Mar 23, 2004 | 08:47 PM
2001SilverGT's Avatar
2001SilverGT
Default gear swap in progress
I just game back from Alamo Perfomance with a RICHMOND ring and pinion set .. the installation kit is coming in tomorrow .. total was $360 = 3.73s
So other than the installation kit and the ring and pinion, i do not need anything else..
correct????
How can I fix the speedometer with the new gears in??
thnx for the help ..
Old Mar 24, 2004 | 01:01 AM
Brian18034's Avatar
Brian18034
Default RE: gear swap in progress
Are you planning on installing them yourself?
The reason I ask is I had mine done by a dealership. I believe you have to set backlash by installing shims, there may even be a special tool to do that (too tight or loose and it will self destruct) I would assume the install kit comes with seals, crush washers and friction modifier.
Old Mar 24, 2004 | 01:07 AM
Brian18034's Avatar
Brian18034
I have heard of 2 methods of speedo correction-
1. Performance chip
2. Speed calibrator (black box wired into car)
Old Mar 24, 2004 | 01:10 AM
2001SilverGT
LOL I WISH .. THEN I WOULD SAVE $150 ..
THNX FOR THE INFO
musnicki
Sep 23, 2015 07:11 AM
jaiidutch
Sep 14, 2015 10:29 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
