CAI or just Filter?
Old Apr 5, 2004 | 12:32 AM
  #21
roundman's Avatar
roundman
Default RE: CAI or just Filter?
me thinks the young lad is blowing a hugh cloud of smoke, whether it goes up your a** is up to you!
Old Apr 5, 2004 | 12:38 AM
  #22
Obsol3te's Avatar
Obsol3te
so would that be fine then?
say i got a CAI but opened up that fender so the air from around the passanger side foglight fills the fender with nice cool driving air
would that be ok?
it would stop the majority of the water n junk too, being a HUGE *** foglight sitting there...
i could imagine it would be better than a normal CAI, but would that be ok with my 75mm MAF?
Old Apr 5, 2004 | 12:50 AM
  #23
roundman's Avatar
roundman
plenty of cold air already gets up there without having to remove the foglights!
I only did mine the way I did because I removed the lights and support bracket to save weight, especially off the front end of the car.
it won't hurt the MAF either, it don't know the difference about where the air comes from, it just measures the air flow as a function of the temperature change in the heated wire in the sensing element, bigger temp change = higher air flow and the meter signal to the ECU changes accordingly as the air flow changes with the throttle position. BTW, if you can use a MAF after a turbo or supercharger, the turbulence in a normally aspirated system sure as hell ain't going to affect it enough to matter one bit.
Old Apr 5, 2004 | 01:01 AM
  #24
Obsol3te's Avatar
Obsol3te
no no, im not talking about REMOVING the foglight, just if the fender didnt already AIR out to it
like air would go around the circumfrance of the foglight that small area, and go up into the fender feeding my air filter
Old Apr 5, 2004 | 01:05 AM
  #25
roundman's Avatar
roundman
humor me! go take a flash light outside right now and look down into that hole in the fenderwell and come back and tell me what you see!
Old Apr 5, 2004 | 01:10 AM
  #26
Obsol3te's Avatar
Obsol3te
hehe
but i HAVE NO IDEA what im talking about
im just guessing
does it go out to the foglight?
Old Apr 5, 2004 | 01:13 AM
  #27
roundman's Avatar
roundman
take the flashlight outside and see for yourself!
Old Apr 5, 2004 | 01:14 AM
  #28
VertStangGT86's Avatar
VertStangGT86
The point is there's a huge empty area in there if you take the silencer and tubing out and you don't have to worry about trying to get more. The foglight won't make a real difference.
Old Apr 5, 2004 | 01:15 AM
  #29
roundman's Avatar
roundman
damn vert, I was trying to make him go learn something for himself! you took all the fun out of it. lol
Old Apr 5, 2004 | 01:19 AM
  #30
VertStangGT86
LOL, oh well, with all of his plans he's gonna do plenty of learning, right obsol3te?
