CAI or just Filter?
Old Apr 2, 2004 | 12:41 PM
Obsol3te's Avatar
Obsol3te
Default CAI or just Filter?
and if i got a cai would i notice a diff? if this isnt one ...(the kid i bought the car off of has an Airbox for this that reaches out to the front of the cars grill on the bottom left that he hasnt dropped off yet)
Old Apr 2, 2004 | 02:18 PM
bmorrisj's Avatar
bmorrisj
Default RE: CAI or just Filter?
nice HAI you got there [8D] all you need is the pipe that bends into the fendewell, thru that hole on the left....and where is your idler pulley...
Old Apr 2, 2004 | 02:36 PM
Obsol3te's Avatar
Obsol3te
I don't know... thats all I have for pulleys...
Old Apr 2, 2004 | 02:40 PM
VertStangGT86's Avatar
VertStangGT86
That bar going from the water pump to the alternator looks adjustable, almost like that works as a tensioner instead of the normal pulley, that's weird.
Old Apr 2, 2004 | 02:44 PM
Obsol3te's Avatar
Obsol3te
hrmm ok then so thats how i'll try adjusting my belt then
Old Apr 2, 2004 | 02:52 PM
roundman's Avatar
roundman
you really ougth to lose that big filter and put a stock filter system back on at that hole in the fender to the left and then you'll have a true cold air intake. you can run a K&N there but you need the stock intake box and pipe towards the throttle body. cut the pipe as needed to install the MAF and you're in business with cold air and yes, you will see a difference over what you have now.
Old Apr 2, 2004 | 02:56 PM
Obsol3te's Avatar
Obsol3te
What if i got the air box from the kid i bought the car off of?
it covers the filter and pipes down to here
[IMG]local://upfiles/4154/Tr509767133.jpg[/IMG]
Old Apr 2, 2004 | 03:03 PM
roundman's Avatar
roundman
that's what you need but I don't know if I would put the pipe on down to the bumper as you can suck up a lot of water when it rains. I would leave off that pipe and just get the air out of the fenderwell where it will be dry. You can always enlarge the hole in the fenderwell with a sawzall or a cut off wheel on a grinder to get more surface area too. I did mine with a Dremel tool but it used up a lot of blades doing it this way b/c there is some double thickness metal at the hole you have to cut through. The homemade ram air I put on my Stang starts at the foglite hole and comes up like the others do, but then I don't run mine in the rain either.
Old Apr 2, 2004 | 03:12 PM
Obsol3te's Avatar
Obsol3te
ok screwit
ill just order a new CAI from BBK off the summit,
or do you reccommed another brand?
heres what im looking at
its the fenderwell version
also, i want to get like the ignition system or whatever its called out of the way too
along with fuel
i think vfast said a 190lph pump?
and didnt really specify what regulator,
hows a 29-74psi sound?
and i should get a gauge for it too right?
also what brands?
I want to order all this for today
Old Apr 2, 2004 | 03:28 PM
roundman's Avatar
roundman
save your money, just put the stock box back on the fender with a filter and you'll be $150 to the good! the pump size sounds about right, and any regulator should be OK, i got one from Aeromotive for $109. yes you need a gauge to adjust it with. i bought one from Autometer and installed it in a cup mounted on the cowl right in front of me so i can see it going down the track. the gauge, mounting cup, and SS braided hose to install it cost about $100 total, damn hose alone was $42! I'm still using the stock ignition in mine and it still does just fine! I eventually will switch to an MSD system later.
