saleen series II gasket replacement
I have a saleen series II (eaton mp90) supercharger on my 2001 mustang, and I need to replace 2 of the gaskets (blower to adaptor plate, & adaptor plate to intake manifold). saleen does not have these in stock, and they will not divulge the type of material they use. I was wondering if anyone knows the material they use so I can cut out the gaskets myslef, or if there is a rtv silicone that can be used.
Thank you!
Thank you!
RE: saleen series II gasket replacement
when i had a series 2 blower for a short time, i took it off the manifold to check the gasket. its just a silicon gasket, nothing special. any rubber gasket material will be fine. dont use the rtv, its messy.
