big block swap into sn95
Old May 13, 2006 | 02:28 PM
  #21
myshifter's Avatar
myshifter
I ♥ Acer
Default RE: big block swap into sn95
If your gonna cut the car up do a 4 link over a ladder bar, ladder bars are easy to setup for people but have virtually 0 adjustability as compared to a 4 link. I dont know how tall you are either but factor in that ladder bars are much longer than a 4 link which means moving the driver seat farther towards the steering wheel. I am 6'6" and I could never drive a ladder bar car
Old May 13, 2006 | 08:44 PM
  #22
JD1969's Avatar
JD1969
Pro. B.S. caller outer
After reading the replys of the original poster I think that he might indeed be able to pull this off with some success. You see most of the members here think that just slapping in a 460 will get them a fast car. marcus77 seems to actually know a thing or two about this stuff, sorrif doubted you marcus77. Shifter I like the new avitar, I can't help but feel that it is directed towards me a bit, realize that I have been a big block Mopar guy for years, so I know what the potential of a big engine is. Persoanlly I don't consider 10.4's all that fast for a engine as big as a 460 but thats beside the point. Good luck on your build man.
Old May 13, 2006 | 09:00 PM
  #23
myshifter's Avatar
myshifter
I ♥ Acer
ORIGINAL: JD1969
Nha man not directed towards anyone. Yes I have seen my fair share of big junk in mustangs. I have only been here 4 days and see that most members are fairly young without alot of experience, but that's ok. I was there once also. He can pull off a deep 9 second car fairly easily. If he doesnt get ahead of himself. Stick to fundamentals and make the car hook, thats key.
Old May 14, 2006 | 02:46 AM
  #24
NeoTokyo's Avatar
NeoTokyo
Personally I think its a cool idea, there are alot of parts that I have seen through experiance that is made for the 460 class, you can either go high rev short stroke or monster torquer stroker, you can go lots of different ways. I have always been this way since my first baby, my Chevelle. I am a high revvin short stroke kind of guy, I like the high revs and horsepower. I know that its not always best for the 1/4 miles and for sure not the 1/8 but I like being able to take something to 7500rpms to shift and know that I can still take it to 8500rpms before hurting it. I like 427's, thats my kinda thing and thats what I am eventually going to build for my Chevelle, right now I have a 396 for it 0.030 over to a 402. Its going to go another 0.030 over to a 408 and if I go another 0.030 over it will be a 413 and I will still have another 0.030 to go (1965 Original Cast) before its too much. The stroke is a 3.76" stroke which is a great stroke for that engine. If I went with a 4.184 bore x 4.0 stroke I would have a 440 out of that thang But I dont know if I am going to go that much.
Anyways this isnt a chevy forum, Have fun with that 460 and if you get the aluminum heads and intake you wont be all missballanced, though thats some expensive shiz.
-Eric-
Old May 15, 2006 | 05:22 PM
  #25
marcus77's Avatar
marcus77
this is an idea I had with my first mustang about 6 years ago but never really got into it. It's a done deal now, my 306 went with a phone call and I pick up the 460 and c6 today in trade for a t-5. I thought was a pretty good deal since essentially I could just put a carb on the motor and go right now. I won't but I could. As for height, I am short...5'7" and only weigh 155 lbs so moving the seat up is no problem. I have been tossed over the ladder bar vs 4 link this whole weekend. I think with my financial ability I will wait to stroke it but I will rebuild it with the kit summit has for $550, the tranny is next not sure just yet on price but it's gettng a transbrake, and then the rear clip. thinking of selling the 8.8 and having the 9" from the donor truck shortened and built. some aspects of the plan I haven't worked out completely but this is only day 3 so I think I have made some good progress with the planning. I have a few freinds that are really good welders and I am not too bad with fitting things to be welded, used to do that for a machine shop years ago. I might wind up with the exhaust manifolds for a while until I can have someone custom make some headers for me, was thinking about Kooks. I just really want to have this thing well planned otherwise nothing that good will come from it....it will not hook up, look like crap, etc.
Old May 18, 2006 | 09:59 PM
  #26
marcus77's Avatar
marcus77
well I was thinking about not really messing with the rebuild for a little bit but the numbers on a compression check seem a little iffy. Tell me what you guys think
#1 140
#2 115
#3 110
#4 135
#5 125
#6 140
#7 125
#8 120
I was told that a basic rule of thumb for compression testing was that all cylinders should be within 15% of each other and I have the largest margin at about 21.5 percent. I do plan on rebuilding the motor but I was kinda wondering on when I would have to. If I just take it out and reseal it and have a valve job done on the stock heads I could have it up alot sooner. What do you guys think?
Old Jun 15, 2006 | 10:51 PM
  #27
bb 460's Avatar
bb 460
I'm in the middle of my 460 swap and I'm having trouble with fitting the hooker headers with the Ford Motorsport's engine mount's just to give you a heads up. It's tight where the steering shaft goes through and where they both go down by the lower control arms/frame. As for oil pan you have to go with a rear sump oil pan with high volume pump. I got mine through Ford Motorsport as well. It's best to go with an electric rad fan because the motor sits pretty high. A 4" hood scoop is a minimum because of course the motor is so tall but the distributor is up there as well. That's about as far as I am so far.
mustangheaven
Jan 3, 2016 11:20 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
mustangheaven
Sep 29, 2015 11:00 AM
wraith777
Sep 28, 2015 10:49 AM
