Check Engine Light
Old May 12, 2006 | 10:59 PM
mcintyre8981's Avatar
mcintyre8981
Default Check Engine Light
A few months back my check engine light came on so i took it to goodyear to have them check it out. They charged me 100 bucks for the inspection and ended up telling me that it was caused by me not closing my gas tank all the way. Which I still don't think that i did. So they turned it off for me and everything was good for a couple weeks till it came back on again. I'm pretty sure that it's the same problem and i don't want to take it back so i can pay another 100 bucks just to be told the same thing. So i was wondering if anybody could walk me through the steps of maual reseting the check engine light on my 1998 v6 mustang?
Old May 13, 2006 | 12:22 AM
Rook6's Avatar
Rook6
Default RE: Check Engine Light
You have options.
Option 1: Disconnect your negative battery cable for....oh I dunno, 10-30 seconds, then reconnect. This should reset things.
Option 2: Find an AutoZone. They'll scan it for free.
Old May 13, 2006 | 12:44 AM
white_snake's Avatar
white_snake
ORIGINAL: Rook6
You have options.
i have been told by several ppl, that OBD II, you can not reset it by disconecting the battery.
or it might just be for certain years.
you could do what i did and just buy a OBD II scanner
Old May 13, 2006 | 12:47 AM
Rook6's Avatar
Rook6
What'd that cost ya?
Old May 13, 2006 | 12:50 AM
white_snake
i got it on sale for 150.00, reg price was 250.00, so it would have all most been payed off if you had of bought it instead of taking it to the shop[8D]
Old May 13, 2006 | 06:16 AM
SXGT's Avatar
SXGT
HOLY GOD !!! $100 for the inspection??? Auto Zone will read yoru check engine light for FREE
Old May 13, 2006 | 09:58 AM
Black_sunshine's Avatar
Black_sunshine
Check your oil cap.If that is not on right or the seal on it has dirt or is damaged It can turn on the light.also check for any oil inthe engine compartment or any vacume hoses that might have cracks or poped off.If all that is ok.then yes take it some where thats honest.Goodyear is good for nothing.
Old May 13, 2006 | 11:10 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
what was the code? It was most likely an evaporative emissions code for a large leak detected. Leaving the gas cap loose will def set the cel. If it comes back on, they will most likely scan it for free and let you know if it needs further diagnostics. But ask first so there are no surprises.
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
