Help with car
Old Apr 4, 2004 | 12:37 AM
Walter89GT's Avatar
Walter89GT
Default Help with car
the car will turn over but will not start help i dont no much about car but need help anyhelp would be great the car is a 89 lx 5.0 thanks
Walter
Old Apr 4, 2004 | 12:46 AM
dghost22's Avatar
dghost22
Default RE: Help with car
I have faced a smiliar problem with a mustang in the past, it turned out to be the ignition coil. Are you getting fire to the plugs?
Old Apr 4, 2004 | 01:01 AM
dghost22's Avatar
dghost22
If you are going to change the ignition module, here is a bit of advice. Make sure you buy a distributor tool. It is the only toll you can use to remove the ignition coil. I had to learn it the hard way. A standard deep socket will not fit... LOL
Old Apr 4, 2004 | 01:07 AM
VertStangGT86's Avatar
VertStangGT86
To check and make sure your plugs are firing you can take the boot off and hold it near a metal part, when you turn over the car you should see a spark jump from the boot. If they are all not firing then you have a problem between the plugs and the rest of the ignition system. Remember, your engine needs, air, fuel, and spark to run, if it turns over but doesn't start it's not getting one of those three things.
Old Apr 4, 2004 | 03:47 AM
MelloYello's Avatar
MelloYello
If the car is turning over but wont start sounds like fuel.... check your fuel pump
Old Apr 4, 2004 | 04:02 AM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Start by listening when you turn the key fowards for the fuel pump if you hear a hum its cool.
Second if the first worked out is to get a spark plug and take the wire off your distributor and ground the plug while you crank it over if you got spark then move on to the distributor checking cap,rotor,and last but not least the pickup inside the distributor.That is what i bet it is.
I had the same happen to me.You can replace the pick up for like 18 bucks but you have to disassemble the distributor and its a pain in the ***!I went ahead since mine was ancient and bought a new one and recurved it for my own specific tune.
If you are getting spark to your distributor but its not leaving the distributor its that pick up coil.To identify the part im speaking of follow wires that plug into your distributor and look on the inside with the cap off its the little 8 sided shaft that the rotor sits on.
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
