Little roll bar install problem
Old Mar 29, 2004 | 08:37 PM
Sk8trfred's Avatar
Sk8trfred
Default Little roll bar install problem
ok here's the deal I bought an '89 lx 4cy. little rust on body no big deal but when I got inside and starting riping out stuff I found a hole in the floor that looked like a rock hit it from driving in the woods. ok I can weld this back but when I went to hammer the floor flat to weld on the panel for the roll bar main hoop the floor started to fall apart right where it meets the back seat. how can I fix this quick and cheap? I'm not a body expert anything will help.
Old Mar 30, 2004 | 10:41 PM
MelloYello's Avatar
MelloYello
Default RE: Little roll bar install problem
Well sounds like rust has gotten to the poor metal on that baby..... You can get sheets of metal to replace it, and you can buy new tubs for the car...... If its just a small area just cut it out and replace it with a another piece.... Check all the floor board though cause whenever theres rust its usually in more than one place....
Old Mar 31, 2004 | 09:28 PM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Yup!
Get you some sheet metal and cut out the bad and weld in the new.
Old Apr 4, 2004 | 01:26 AM
VertStangGT86's Avatar
VertStangGT86
If you're not comfortable welding or don't know someone who is then I'd take it somewhere to have it done, you don't wanna go ghetto and rivit the panels in, hold your laughs, I know someone who did that one time on an old truck.
Old Apr 4, 2004 | 03:55 AM
MelloYello's Avatar
MelloYello
If your living in an area of the US with humidity and since your already doing work on the underneath part of the car you should think about doing maybe an epoxy or rhino or some sort of a sealant on the bottom itll keep from future rust destroying it again...
Old Apr 4, 2004 | 04:05 AM
TheGmKiller331
I ♥ Acer
If you cant do this at home its not worth the time,money,or effort.
This is barely worth the time if you do it at home but especially not since you may have to pay someone.
drfister
May 3, 2018 10:38 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
kdryan
Aug 21, 2015 04:01 PM
jjwinel78
Aug 17, 2015 03:34 PM
cema93
Aug 10, 2015 09:35 PM
