weird startup problem
Old May 15, 2006 | 12:16 AM
tightdogal's Avatar
tightdogal
Default weird startup problem
hey all. something weird has been happening. when i go to start my car after maybe a day or two, my car kinda like coughs and shakes and chugs before cranking on. it will like start but sometimes in the middle of starting, it wont start. i have to turn the keys again and then it wil start up fine. does anyone know whats causing this big cough hiccup thing? i talked to my parents and they said it could either be the battery or the starter, but the battery is pretty new, i only got it in october so im thinkin it could be the starter...does anyone else have any input as to whats going on? help is apppreciated.
Old May 15, 2006 | 01:02 AM
MusiccityGT's Avatar
MusiccityGT
Default RE: weird startup problem
That sounds like a fuel or spark related issue, not a battery or starter problem.
Old May 15, 2006 | 01:15 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
So are you saying in the middle of cranking, it stops cranking. Then you crank it again and it starts? You need to be a little bit more descriptive w/ your explanation!!!
Old May 15, 2006 | 01:32 AM
tightdogal's Avatar
tightdogal
well i mean itll stop if i let go at a normal turn of starting my car. but in order for it to start up i have to turn the key and hold it for a bit longer while its like coughing and shaking the whole time. get it?
Old May 15, 2006 | 04:53 AM
cobra04's Avatar
cobra04
sounds like a spark problem check your ignition system from the cheapest components to the most expensive and complex see which one is malfunctioning,it could be the spark plugs the spark plug wires or the coil.
Old May 15, 2006 | 04:07 PM
tightdogal's Avatar
tightdogal
hmmm.interesting i will. if any other suggestions are here, ill gladly take em
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
MasterLanMan
Sep 13, 2015 08:21 PM
