Door Moldings
Old Apr 4, 2004 | 05:50 PM
JustinBHR's Avatar
JustinBHR
Default Door Moldings
How do you take off the door moldings? I'm getting the car painted and would like to have them painted separately.
[IMG]local://upfiles/5867/Tr492037946.jpg[/IMG]
Old Apr 4, 2004 | 08:26 PM
MelloYello's Avatar
MelloYello
Default RE: Door Moldings
If youve got eletronic windows you need to remove the window regulator handle... the plastic part of the door that has the controls on it.... you should be able to pry the top if out first then the bottom will release... All your wires will be held into place with screws take them out.... there might be a couple rivets also... Remove the door handle trim cup, should pry out.. .and then along the door you should have more plastic rivets that you pull out, (when reinstalling you may want to use new rivets from ford, there cheap)... Then there should be retaining screws from where you took out the door bezel from...... Then the panel should just lift out... Remember to disengage any wiring harness's....
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
breaking
Oct 2, 2015 01:27 PM
b8checker
Sep 30, 2015 07:11 AM
Sep 25, 2015 06:58 PM
