Jackstand placement
Old May 20, 2006 | 03:04 PM
rcobra's Avatar
rcobra
Default Jackstand placement
i own a 1994 cobra. need to know the proper place to place jackstands front and rear. i have a floor jack and do not wish to use the regular tire changing points described in the owners manual.
Old May 20, 2006 | 08:25 PM
kartracer55's Avatar
kartracer55
Default RE: Jackstand placement
The oil pan is always the best place to jack up the car
No but seriously... what are you trying to do? There are different points on a car, some are better than others depending on the job your doing
Jim
Old May 21, 2006 | 01:35 AM
gspfunk's Avatar
gspfunk
under the A arms in the front, or K member and on the rear axle toward the sides for better stability.
Old May 21, 2006 | 02:57 AM
OnyxCobra's Avatar
OnyxCobra
place them on the frame. There is a part of the frame at each corner of the car; just behind the front wheels and just infront of the rear wheels, about a foot in maybe, u cant miss em...
Old May 21, 2006 | 09:59 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Either of the last 2 will work fine
Old May 21, 2006 | 04:07 PM
rcobra's Avatar
rcobra
After checking this placement out i will use the flat area in front of the rear wheels in about a foot, and just behind the front wheels in line with the lower control arms is a rail about 3" wide. Is this considered the frame rail?. I did see where some of the paint and undercoating was scrapped off at these four points from the service lifts at the Ford dealer.
Thanks to all for the info.
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
LivingInThePast
Sep 16, 2015 12:20 PM
Mustangn
Jun 12, 2006 12:28 AM
Sap
Apr 10, 2006 06:26 PM
67Dan67
Mar 5, 2006 01:45 PM
