car not starting
Old Apr 11, 2004 | 10:12 PM
dghost22's Avatar
dghost22
Default car not starting
I got the Gt back together today. It fired right up. I let it run for a few minutes just to check for fluid leaks and everything was fine. I went to take it for a drive and started it up. It started fine. It ran for about 30 seconds then the tach dropped. The motor ran for maybe another 2 seconds at normal idle, then it also died. It has not started since. I replace the ignition module thinking that may be the culprit. Same issue. I replaced the coil thinking that maybe help, same issue. Any ideas here. I mean, there is not much to the ignition system, unless I am overlooking something. PLEASE HELP....
Old Apr 11, 2004 | 11:03 PM
VertStangGT86's Avatar
VertStangGT86
Default RE: car not starting
Fuel, spark, and air. That's what you need to start. Maks sure the engine's getting fuel. Does your engine turn over at all? If it at least cranks then you can check and make sure you're getting spark. Pull the boots off and see if it will spark when you hold it near metal and crank the engine. If not your problem is somewhere with that. If not then it's probably a fuel problem, can you hear the pump run when you turn the key? Check that stuff out and let us know what you find out. Good luck
Old Apr 12, 2004 | 12:22 AM
dghost22's Avatar
dghost22
I have narrowed it down to electrical. I have fuel and air, but I am not getting spark from the coil. I have replaced the coil and the ignition module, still no fire in the coil....WTF? Any advice on that one? Another question, the harness that runs into the tfi coil, where does it go from there? I can trace it back to the firewall but after trhat, I have no idea.....
Old Apr 12, 2004 | 01:08 AM
bossman351's Avatar
bossman351
It deffinately ounds like electrical. Try a scanner It can tell you alot about your car by just plugging up to the diagnostic port. It could be in the distributor its self or even the ECM. If you dont have access to a scanner you can go to a parts house and get a diagnostics tool which works kinda like a scanner only a little more low tech.
Old Apr 12, 2004 | 02:36 AM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Ok here you go ive pretty much figured it out for you based on your posts.
But check a few things to help pinpoint it.
First get an old spark plug or hell pull one from the car and use it.Next put it in the end of the wire going to your distributor and have a buddy crank the car over.If youre getting fire from it thats good.
Second (IF YOU GOT FIRE FROM THE FIRST TEST) take that same plug and put it into one of any spark plug wires coming off the distributor and crank it over if you are not getting spark now but was the first time you have a bad pick up coil in the distributor.
If this in fact is the problem you can (A) get a new pick up coil from an autoparts store for about 20 bucks.But you need to know how to assemble and disassemble a distributor which can be a bitch some times.
Your second option is to buy a new one.If this distributor is older i recommend replacement.Or an upgrade to a better one.
If you have any questions let me know ill help you out.
Old Apr 12, 2004 | 10:46 PM
dghost22's Avatar
dghost22
LOL, you are good. It turned out to be the pickup coil. Since the distributor is the only thing in the ignition system that is not MSD on my car, I replaced the distributor with an MSD distributor after I replaced the pickup coil in the old one. That was a pain in the a**. I had a hard time getting the gears off to pull out the shaft. Even after the pins were out.... anyway, to make a long sotry short, thanks for the help all
djbigskrilla
Sep 20, 2022 01:04 AM
drumhedd2005
Aug 13, 2015 09:59 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
89blueslug
Aug 10, 2015 07:20 AM
