Q about the "cold" in CAI
I was lookin at some CAI setups and some systems claim "colder" air than their competitors, as well as certain setups pulling in colder air than others. This doesn't really make sense to me. If the outside air is a set temp (even factoring in the wind blow), how could one setup pull in colder air than others? Now I can understand pulling in "more" cold air, but "colder"? I just don't get it. Case in point, straight shot vs. regular ect...
RE: Q about the "cold" in CAI
Some CAI have the filter directly in the engine compartment, they will draw in warmer air than other intakes that have the filter sitting in the fender well that will draw in somewhat cooler air. Also some intakes have the tubing from the filter to the throttle body that are plastic instead of aluminum, since plastic disipates heat and will not heat up as much as the aluminum tubing.
Yea the factory setup already IS a CAI in a Mustang. But what they're referring to is.. how effective a particular brand CAI is at preventing hot underhood air from seeping into the intake. A fully fender fed CAI is MUCH better than those ones where the air filter is fully exposed under the hood
ORIGINAL: Rook6
So I'm actually losing horsepower with the CAI I have? I mean it does have a larger inlet and straighter path to the throttle body
Some people believe that the plastic CAIs are better because they don't absorb as much heat. Whatever. I have yet to see any solid testing showing any differences between plastic and metal CAIs. Besides, we're not talking big numbers here, anyway.
everyone says that the aluminium pipe will warm the air because of it getting hot from the engine, but in reality, the air being sucked in is moving too fast to be effected by the heat.
+10. Good catch.
ORIGINAL: ARdoller
