Bad Batt. or Alt.?
Old Apr 17, 2004 | 09:50 PM
Lennyseleven's Avatar
Lennyseleven
Default RE: Bad Batt. or Alt.?
Problem is it still wont start the car. I had it charged and tested and the parts store said it was fine. So what is the recommended cranking amps?
thanks
Nick
Old Apr 18, 2004 | 01:59 AM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
My battery is 800CCA,
In fact my 2.3's was like 640CCA i think you need a bigger battery and i couldnt tell but does your alternator charge?
Old Apr 18, 2004 | 11:44 AM
Lennyseleven
I tried taking off the negative while it was running like someone said and it stayed running so... I guess so
Yea I noticed my 3.0 V6 in my van has higher cranking amps
thanks
Nick
Old Apr 18, 2004 | 12:25 PM
roundman's Avatar
roundman
500 cca should be plenty to start the engine. check the postive cables at battery and the solenoid and the starter for a good clean connection and make sure they are tight. if the cable has a lot of corrosion at the terminals anywhere it connects to something, replace it as this kills the current flow which is not good for the high amps needed to crank the starter. worse case, the starter could be bad and drawing too many amps also and a weak battery won't turn it over fast enough to start the car.
Old Apr 18, 2004 | 12:30 PM
vfast's Avatar
vfast
I ♥ Acer
maybe you have a tired alt. you can't go by those sorry *** stock gauge..have the alt. tested have then but a hugh load on it.. how is the water level in the battery?
GM...how many 'puters have you bought by pulling the battery cable off?..it isn't like it used to be...
Old Apr 18, 2004 | 07:00 PM
VertStangGT86's Avatar
VertStangGT86
I've done that plenty of times on mine and never had any problems. Never heard of anyone frying their computer by pulling the battery cable off, doesn't really make any sense that that would do anything bad.
Old Apr 19, 2004 | 03:01 PM
roundman's Avatar
roundman
you have been lucky! the computer only needs one good voltage surge to blow its brains out, so I would not recommend removing the negative cable with the engine running to test the alternator, it ain't worth the risk to ruin a $300 computer for a $35 alternator.
Old Apr 19, 2004 | 03:09 PM
VertStangGT86
Would the voltage surge come from reconnecting the battery while it's running or disconnecting it? Also where are you gettin $35 for an alternator?[8D]
Old Apr 19, 2004 | 03:38 PM
roundman's Avatar
roundman
it don't matter which way, a surge is a surge and it could get the ECU.
I think that was at Trax Auto some years ago, but being old I may have it wrong too![sm=lol.gif]
my point remains the same, it ain't worth the risk when all you need is a $10 voltmeter to check the alternator output. and that's a Pep Boys price btw.
Old Apr 19, 2004 | 05:10 PM
TheGmKiller331
I ♥ Acer
Ive done it to countless cars!
With no problems what so ever.
I disconnect the cable if the car dies i shut the key off attach the cable back and go about removing the alternator.
If it stays running ive never attatched the cable back while running that can cause the power spike you are worried about.
And Vfast we are talking a 14 year old stang here its not rocket science.
Like i said i have had no problems doing this but thats not to say theres not going to be freakish incidents happen.
