hanging idle with a/c on
Old May 31, 2006 | 10:47 PM
99blacksvt's Avatar
99blacksvt
Default hanging idle with a/c on
hey everyone im new to this site and i have a quick question. When my ac is on in my 99 cobra the idle hangs at around 1500-1800 rpms for a few seconds before returning back to normal when the clutch is pushed in coming to a stop light or any time i stop. Does anyone know a cure for this. I have already tried cleaning the iac, and i have an iac restrictor in it now and it does the same thing. I also checked the voltage to the tps and it is a .989 volts
Old Jun 1, 2006 | 08:24 PM
Gaspi101's Avatar
Gaspi101
Default RE: hanging idle with a/c on
ORIGINAL: 99blacksvt
You don't need a cure. This is normal. It's a bit high, but elevated RPMs for a number of seconds when coming to a stop, or to a lesser degree, every time you have the A/C on...is totally normal.
In order to run the compressor, considering the humidity in the car, etc., the A/C system requires a lot from your engine. Elevated RPMs are all part of the way things work. If you want to lower them you could adjust your throttle-body accelerator cable, or even mess with the computer. If you do that, you may end up damaging your A/C system permanently.
I suggest you do nothing. Your car's running fine. :-)
Old Jun 1, 2006 | 09:55 PM
monkeydude3's Avatar
monkeydude3
yeah it's normal. it's so your engine doesn't die with the a/c on. my GT does it sometimes too
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
BeatnikFink
Oct 1, 2015 08:00 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
69Volunteer
Sep 30, 2015 10:39 AM
