Door Sagging
Old Jun 2, 2006 | 11:52 PM
doogie's Avatar
doogie
Default Door Sagging
Having an issue with the driver side door on my 95 V6 Mustang Coupe, the door alignment seems to off, I would say about half an inch. Just wondering if anyone knows what is needed to correct the alignment?
Any help would be appricated since the door doesn't really want to latch anymore and has a tendency to fling open while driving :P
Old Jun 11, 2006 | 05:15 PM
I_AV8_4U's Avatar
I_AV8_4U
Default RE: Door Sagging
Hey Doogie...
Sounds simply like one of the hinges (or both) are going bad. These don't cost that much, about $30 each if I remember correctly. They are fairly easy to install, but make sure that you trace the old hinges befor you pull them...aligning these things are a BITCH!
Good luck.
Troy
Old Jun 11, 2006 | 11:35 PM
SXGT's Avatar
SXGT
ist the hinge or the metal is worped , pray it not the latter
Old Jun 12, 2006 | 02:22 PM
newbikerider2003's Avatar
newbikerider2003
Also check out the local NAPA or others, some of the pivot pins and bushings are sold cheap. You cut through the pin and remove the door without changing the hinge placement.
jerrytubes
Oct 23, 2015 12:11 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
Sep 25, 2015 06:58 PM
