Staring Problem HELP ME !!!!!
Old Apr 19, 2004 | 04:14 PM
BPLax21's Avatar
BPLax21
Default Staring Problem HELP ME !!!!!
ok i have an 89 stang 5.0, cobra upper/ lower intake, 65 mm. tb, cold air indiction, E-303 cam, etc. i just recently removed my smog pump and also installed a bbk fuel press. regulator. i have it set at 40psi with the vaccum tube diconnected. (i have stock injuectors) after i did these 2 things ive noticed that sometimes when i start my car it takes longer to fire up, it cranks longer. after it starts it runs fine but it never used to take this long to fire up. i dunno if its with my car not getting enough fuel psi. or what??
also when it starts it backfires in the engine, not the exhaust.
Old Apr 19, 2004 | 10:55 PM
VertStangGT86's Avatar
VertStangGT86
Default RE: Staring Problem HELP ME !!!!!
Well try turning it to the on position and letting the pump run for a minute before starting it. If that helps then it's probably a fuel problem, pressure, flow, or something else. Also I'm looking at getting the E-303 this summer, how do you like it in yours? How much of a differance did it make?
Old Apr 20, 2004 | 01:46 PM
LLADNAR's Avatar
LLADNAR
backfire through the intake is usually a timing problem, maybe you need to get to a dyno and get that regulator tuned in and get it timed according to your new regulator
Old Apr 20, 2004 | 02:51 PM
BPLax21's Avatar
BPLax21
yea vertstang, i love that cam, it sounds sick when it idles. it like romps its a sick sounds i love it. as for performance im guessing it makes some good hp but i dunno, i got it put in with my intake, tb and cai so it wasnt just like i did that mod and could tell a difference besides the sound from just the ecam.
Old Apr 20, 2004 | 02:52 PM
roundman's Avatar
roundman
sounds to me like the pressure regulator is bleeding off all the pressure after you shut the car off and it takes a couple of seconds for the pressure to build back up when you first turn on the key after it's been sitting for awhile. just pause a second or two after turning the key on the let the pressure come up and see if it don't start quicker this way.
1TUFF302
Nov 5, 2015 04:02 PM
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
