cut out exhaust
Old Apr 20, 2004 | 11:13 AM
GTmartin1713's Avatar
GTmartin1713
Default cut out exhaust
does anyone have an opinion about cut out exhaust using a Y pipe to where i can expose it to make it sound bad *** or cover it with wing nuts and make it sound stock.
Old Apr 20, 2004 | 11:19 AM
SilverGTV8's Avatar
SilverGTV8
Default RE: cut out exhaust
If you want to do that spend the extra cash and get electric cutouts. A couple of times of crawling under the car to cap and uncap will make it worth while.
Y pipe? That's an F-body part unless you drive a 6 cylinder. You have an h pipe or if you swapped it to an x-pipe. You would need two cutouts either way.
It sounds ok just really freaking loud. Good if you only plan on using at the track and want to keep the stock exhaust. Probably spend the same amount of money getting the cutouts, installing them, as you would for a nice catback. but you will see better horse power gains with cut out but a drop in torque.
Old Apr 20, 2004 | 04:25 PM
USAMuscle's Avatar
USAMuscle
The Y-pipe I think he's referring to is the actual cut-out pipe you install before the mufflers that opens up for open exhaust, or you can close it off for driving on the street. Also, Y-pipe isn't only an F-body term. GTs 1985 and prior had Y-pipe exhaust systems. If you want a cut-out go for it. It is pretty loud without mufflers though. I drove my '96 for awhile without mufflers with the stock H-pipe and man it was freakin' loud! A little too loud for me, especially with the exhaust dumped right underneath the car.
Old Apr 20, 2004 | 05:25 PM
VertStangGT86's Avatar
VertStangGT86
It's def too loud unless you're gonna go with the cutouts just for racing or something. I'd go with the ones you can operate from inside instead of getting underneath all the time. The 85's had a different tranny crossmember for the Y. don't know what year you have but if you have an old one and wanna upgrade you just need a new crossmember, the double hump one.
Old Apr 20, 2004 | 05:48 PM
white93 GT's Avatar
white93 GT
MY FRIEND HAS STOCK EXAUST ON HIS 92 LX AND NO MUFFLERS AND ITS OK BUT IT COULD BE LOUDER. DOES PUTTING ON AN OFF ROAD H PIPE MAKE THE CAR ANY LOUDER?
Old Apr 20, 2004 | 08:19 PM
VertStangGT86
Oh yes, def does. And about the original question I wasn't thinking on the right track before. It's a good thing if you wanna race but I don't know if I would run them on the street.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
69Volunteer
Sep 30, 2015 10:39 AM
b8checker
Sep 30, 2015 07:11 AM
Sep 24, 2015 09:18 PM
