WARNING:Bumper insert letters
Old Jun 8, 2006 | 01:03 AM
CoBrAbRaT's Avatar
CoBrAbRaT
Default WARNING:Bumper insert letters
Wanted to hopefully save someone some grief.
Bought some bumper inserts (stainless steel) from a reputable source. There were no instructions and it seemed straight forward enough to install them......stick the double sided tape on the back of the letters and plop them on. No Problem.
Little did I realize that surface that the letters go on is not completely flat. To avoid a huge problem, I should have dry fit them. I would have bent the letters with slight curves so that they contoured with the curves in the bumper. Mine are COBRA. I ended up bending the bottom of the B R and A considerably. I also had to curved all the letters crossways slighty.
Perhaps the thickness of the material is important. Mine are 14 gauge. I think some places have 16 gauge. I think the thinner the better.
Anyways, they look great. Hope this helps.
STEVE
Old Jun 8, 2006 | 01:22 AM
99BlackV6's Avatar
99BlackV6
Default RE: WARNING:Bumper insert letters
Yea I had that same problem. I just let it go because unless you up close you cant see that the bottom isn't touching.
Old Jun 8, 2006 | 01:51 AM
antiv6's Avatar
antiv6
this is probably the easiest thing you could do. all you do is stick them on. Mine came with no instructions and they went on perfect
Old Jun 8, 2006 | 03:51 PM
pdk's Avatar
pdk
if theres any wax it wont stick.
mine didnt stick well even aften i cleaned the surface to remove the wax.
some sellers provide you w/ a 3m cleaner to help ensure the stick
Old Jun 8, 2006 | 04:02 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
I happened to notice that the letters were perfectly flat before I installed them and bent each of them to the right shape before installing them.
Old Jun 8, 2006 | 04:03 PM
antiv6's Avatar
antiv6
you can use rubbing alchohal to take the wax off
Old Jun 8, 2006 | 06:06 PM
pdk's Avatar
pdk
i tried alcohol several times before putting them on...
the rep i bought them from emphatically said "dont bend them" when i asked, so i listened.
Old Jun 8, 2006 | 06:25 PM
GreyStang's Avatar
GreyStang
I can see where you'd want to bend them to make them fit nice & flush. But if they're chrome/SS then wouldn't the reflection look weird if they were bent?
mtgldr
Feb 3, 2024 09:00 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Sep 16, 2015 07:53 PM
Ford_Dude
Sep 15, 2015 03:25 PM
Sep 1, 2015 08:16 PM
