axle dampers.
Old Jun 8, 2006 | 12:23 PM
ponystock2's Avatar
ponystock2
Default axle dampers.
Does anyone know what year modle and type mustangs had rear axle dampers on the rear end, or (quad shocks.
Old Jun 8, 2006 | 12:30 PM
Twister's Avatar
Twister
Default RE: axle dampers.
depends on your definition of axle dampener, all Mustangs have a dampener (shock) that somehow attached to the rear end (some times to a plate bolted to the rear), the 1984 SVO had the first quad shock, about half way through the run
Old Jun 8, 2006 | 12:58 PM
ponystock2's Avatar
ponystock2
not all mustangs have dampers they might have shocks but no dampers the damper lay on top of the rear end they are horizontal.
Old Jun 8, 2006 | 12:59 PM
Twister's Avatar
Twister
ORIGINAL: ponystock2
by definition, a shock is a damper
Old Jun 8, 2006 | 04:14 PM
anthonydalrymple's Avatar
anthonydalrymple
The "quad shocks" were on all V8 Mustangs from '87-'93(from what i do in fact know). I'm sure there are other applications.... Why are you asking? If i may ask that is.....
Old Jun 8, 2006 | 04:45 PM
ponystock2's Avatar
ponystock2
Im going to use it for dirttrack racing 4 cyl, those handle so much better than with out them.
Old Jun 9, 2006 | 01:29 AM
anthonydalrymple
The a trip to the junkyard is in order to get your hands on the frame mounting brackets & the quads if in good shape. If you only need the quads; you'll have a difficult time getting them from most parts counters..... they will not have a clue..... But, if you ask for thier Gabriel shock manual, look up "steering stabilizers" in the index, go to that page? You will find a one line entry for the Mustang quad shocks with part number.....
Old Jun 9, 2006 | 12:46 PM
Twister's Avatar
Twister
ORIGINAL: anthonydalrymple
Tony, late 84 SVO's, and 85-93 5.0's....
Old Jun 9, 2006 | 10:53 PM
anthonydalrymple
ORIGINAL: Twister
Oh...... I don't doubt you mha man. I simply am speaking only of experience that I have & absolutely know. It would be irresponsible of me too state other years of this option being available if i did not know it as fact. I simply gave info that should meet this gentleman's needs....
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
Sep 24, 2015 09:18 PM
Sep 10, 2015 08:39 PM
