I want help with Installing the Original Springs
I run a 315/35/17 rear tire set up on my 94 GT. But My tires hit on the outer edge of the Fender on turns or dips in the road. I was just wondering what do i have to do to Replace the springs? Such as Jack the car up and undo the shocks then the spring should fall out more or less Right? Can anyone tell me how to do this? please I'm having a brainfart....
PS This springs i want to change are on the rear of the CAR
That's about it, you just gotta make sure you jack up the car by the body so the axle can drop down and let the springs out. Should be able to unbolt the top of the shocks before you jack it up and then they should drop right out.
All done. Replaced all 4 Spring to Original. Much better being i have 315/35/17 on the back and 255/45/17 on the front. The tires were hitting. Thanks for the help
Oct 5, 2015 06:07 PM
Sep 1, 2015 08:16 PM
kawiguy827
Sep 1, 2015 07:09 PM
