REAR BRAKE CLIPS ON PADS
Old Jun 12, 2006 | 02:02 AM
sfi's Avatar
sfi
Default REAR BRAKE CLIPS ON PADS
Does any one know if the clips on the rear brake pads are neccesary to reuse, Secondly, if they are, how the heck do you put them back in with the pads into the caliper.
I can get the back one in, but the front doesn't have enough room with these damn clips.
IM novice at this, but it seems pretty easy, what am i fdoing wrong ?????
Old Jun 13, 2006 | 02:34 AM
Black96's Avatar
Black96
Default RE: REAR BRAKE CLIPS ON PADS
if i'm correct, they are the anti-rattle clips and help keep the pads in the right place (maintaining clearance) and are a b1tch to get back on. i left them off when i changed mine recently and have had zero trouble or noise. the only clips you really need are the ones on some pads that hold the pad to the caliper itself (usually front).
Old Jun 13, 2006 | 11:50 AM
00blustang's Avatar
00blustang
I'm assuming you are talking about the clips attached to the ends of the pads (2 per pad). Yes I think they are necessary or else the pad may rattle around a little. They are tight but the pad will go on with them. Try tapping lightly with a hammer to get them started. Bend down the tabs with you fingers. Good luck.
Old Jun 13, 2006 | 01:44 PM
ncksnapper's Avatar
ncksnapper
they are there for a reason, the hold the pads in place, eventually if there not there they will rattle loose cause uneven rotor and pad wear
Old Jun 14, 2006 | 10:39 AM
dstangrunner's Avatar
dstangrunner
I left mine off. i couldnt get them back on. it seems to be fine. No rattleing. changed them about 30,000 miles ago. Just what i did.
Old Jun 14, 2006 | 11:37 AM
ncksnapper's Avatar
ncksnapper
you guys are a bunch of hacks
Old Jun 15, 2006 | 02:17 PM
ncksnapper's Avatar
ncksnapper
not trying to be an a hole or nothin but not putting back on every bolt or clip that came off is being a hack
musnicki
Sep 23, 2015 07:11 AM
Dragonus18
Sep 9, 2015 01:21 AM
cbird1177711
Sep 2, 2015 04:12 PM
Sep 1, 2015 08:16 PM
