problems with p.i. heads
Old Apr 23, 2004 | 07:11 PM
b96gt's Avatar
b96gt
Default RE: problems with p.i. heads
no knocking at all it runs smooth but after about 15 minutes it doesnt want to idle and it runs sluggesh would a sensor cause that because i have one that isnt hooked up with the right kind of wires
Old Apr 23, 2004 | 07:20 PM
MelloYello's Avatar
MelloYello
What sensor is it? It may very well be a sensor..... Is it the CMP? It could be PCM also
Old Apr 23, 2004 | 07:26 PM
Sidewayz6.0's Avatar
Sidewayz6.0
What code are you getting when the check engine light comes on? This is a no brainer if you know that.
Old Apr 23, 2004 | 08:34 PM
b96gt's Avatar
b96gt
its reading ignition coil a primary/secondary circuit malfunction. po351 does that help cause i dont know what the hell it means
Old Apr 23, 2004 | 08:49 PM
MelloYello's Avatar
MelloYello
That code is a Ignition coil primary circuit fault
Do a test on your coil.. You can do that by using a spark tester
It might also be dirty, check it out... When you test it and theres no spark then its ok...
if the coil wires do have a spark and the resistance is over 7000 ohms p f its bad needs replacing.....
Old Apr 23, 2004 | 09:22 PM
b96gt's Avatar
b96gt
ok i checked the coils and there was no spark from the coil on the driver side. So does this mean that just the coil is bad or is there something else i should check?
Old Apr 23, 2004 | 11:06 PM
Sidewayz6.0
I would start with the coil. They're not amazingly expensive. Give that a shot and see what happens.
That usually means the passenger side is bad. The way it's running you could have the timing WAY off too.
They the coil first.
Old Apr 23, 2004 | 11:16 PM
MelloYello's Avatar
MelloYello
Well buddy if there was no spark... the coil should still be good....
But if thats the code that you are being given, try cleaning it or replacing it and see what happens..
Old Apr 23, 2004 | 11:50 PM
Monty's Avatar
Monty
mello.....are you sure....i thought it was the other way around......but anyways one of the coils is bad no matter what.....cuz one sparks and the other dosent.
Old Apr 24, 2004 | 01:49 AM
MelloYello's Avatar
MelloYello
Yeah dude Im very sure........ I delt with that stuff with my jeeps and a buddies stang....
Yeah replace the one thats sparkin.....
