Need Help, Freak Breakdown
Old Jun 13, 2006 | 11:02 AM
KillSwitchNY's Avatar
KillSwitchNY
Default Need Help, Freak Breakdown
i have no oil pressure. the psi was fine till one day driving on the parkway it suddenly plumetted to 0psi. then a valve tap began. brought it to a shop and they told me the oil pump is bad. put in high volume pump and still nothing. checked the shaft under the distributor and it was fine.
what is the problem?? they said they cranked the car with the oil filter off and it squirted out alot so its obviously getting oil to that point.
they said i will probably need a rebuid but my motor is a fresh rebuild already with less than 10k miles on it and wasnt beaten on till 3k. just a note, they also said there was no sludge or any build up on the pump screen, i change my oil religously.
PLEASE HELP!
Old Jun 13, 2006 | 11:16 AM
P Zero's Avatar
P Zero
Default RE: Need Help, Freak Breakdown
Ever think that the oil pressure sending unit might be bad? That would be the first thing Id replace. Make sure the wire going to it is in good shape.
-P.
Old Jun 13, 2006 | 01:58 PM
KillSwitchNY
oh believe me i wish it was that easy. the thing is the top end is still ticking away.
Old Jun 13, 2006 | 02:02 PM
P Zero's Avatar
P Zero
Id say pull a valve cover, start her up and see if oil sprays all over the damn place. Also, try going to a thicker oil, as in 10w40. If the tick goes away then you probably wore the hell outta somethin. Also, Do you have adjustable roller rockers? If so it might just need to be adjusted up.
-P.
PS: Other than that it sounds like an oil passage is plugged up, which would constitute a complete motor teardown and cleaning.
yurizx6r
Aug 11, 2015 07:50 AM
NOS/MAN
Jul 2, 2004 02:09 AM
drlexington
Jun 1, 2004 12:23 PM
SilverGTV8
Apr 28, 2004 03:56 PM
Ormist
Jan 22, 2004 03:08 PM
